Introduction: COVID-19 UV-C Sterilizer Box
COVID-19 is rapidly spreading. Millions are on lock down around the world. And everywhere there is a shortage of personal protective gear. Therefore single-use equipment needs to be sterilized and reused. That is not how it should be, but it is your best chance to protect yourself until production is stepped up. The European Union recommends the use of UV-C light for sterilization. For a mere 30 bucks you can build a UV-C sterilizer yourself to alter protective gear and daily needs e.g. smartphones, keys, toothbrushes and more.
Caution: UV-C light causes skin cancer! Always close the lid of your box before you turn on the UV-C light. For more information see the European commision's factsheet.
- Sealable opaque Box with open handles
- low power UV-C lamp (no ballast needed)
- E27 bulb socket with power switch
- G23/24 to E27 bulb adapter
- Cardboard
- Scissors
- Adhesive tape
Step 1: Things You Need
- Cardboard
- Scissors
- Adhesive tape
- Tin foil
Please note: electrical standards may vary!
Step 2: Screw in the G23/24 to E27 Bulb Adapter
Easy-peasy!
Step 3: Insert the UV-C Lamp
Easy peasy too. However before you continue I suggest you test the UV-C lamp first, because once the lid is closed, you will not be able to tell. This is important. If the UV-C lamp is not working, you might mistake that the things you put inside the box are sterilized, even if this is not the case.
Caution: UV-C light causes skin cancer! Cover your skin and wear sunglasses. Turn on the light and immediately turn it off if it is working.
Step 4: Cover the Handles
Use the cardboard and adhesive tape to cover the open handles. This is important! Make sure that no UV-C light can emit from the box.
Step 5: Put a Reminder on the Lid
UV-C light can cause skin cancer. It is a good idea to put a little reminder on the lid. I urge you to take this serious!
Step 6: Cover the Inside With Tin Foil
Nothing more to say here, except thank you @iminthebathroom for the hint. With tin foil you can make this sterilizer box even better and more effective. Now it looks like a real oven. Remember to cover the lid as well!
Step 7: Raise Objects Inside
To help scatter the UV-C rays under the item you want to sterilize, it is best to raise those items several inches from the bottom. Use a cookie rack or an IKEA Brunsta Hemma lampshade. Whatever is at hand. Thank you for the kind suggestion @iminthebathroom.
Step 8: Start Sterilizing
Now you can sterilize some of your protective gear and daily needs. Do this on a daily basis. Put all of it inside the box and turn on the light for at least 10 minutes, but remember to always close the lid. Be cautious and stay healthy! For more information on the effects of UV-C light on COVID-19 see
Please note: If you like this DIY tutorial spread the word and help others to protect themselves too. #FlattenTheCurve
Spring Cleaning Challenge
17 Comments
1 year ago
Can we use it sterilising food items , vegetables ?
Tip 2 years ago
This is an interesting read: https://www.bbc.com/future/article/20200327-can-you-kill-coronavirus-with-uv-light
2 years ago on Step 4
Use translucent silicone to seal the wire hole on the box, that way you have a way to see the light is on inside the box. If you worry about leaking UV, turn the box so the peephole faces the wall.
Reply 2 years ago
Hey Bing, that's a great idea. It would make things a lot easier. To see if the light was on I dressed like a mummy. :D Thanks for the tip!
Question 2 years ago on Step 1
Hi thanks for sharing your project - really helpfull ! I am just conerned about the voltage : I find only 60V bulbs, is it ok to work on 230V ? Not really sure here. Or your bulb is 230V input ? if so could you tell me the ref ?
thx
Answer 2 years ago
My lamp works on 220V and 230V according to some feedback I got at amazon. https://www.amazon.de/Philips-Kompaktlampe-PL-S-Watt-Teichkl%C3%A4rer/dp/B006D7LNVE/ref=sr_1_3?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&keywords=philips+uvc&qid=1584529003&sr=8-3 I hope this helps.
Reply 2 years ago
Ok I get it now, the transformer is inside the adaptor :) Thx and stay healthy !
Reply 2 years ago
Great to see how everyone is working together to get answers to the questions I could not answer. I hope you all are safe and healthy. Let's keep it that way! Greetings from Bochum, Germany.
Reply 2 years ago
This is great! [And very timely given all the C-19 concerns!]
Sorry - I'm still a bit confused! The Philips datasheet states that this is a 46v bulb: Does the adapter do anything other than physically convert the G23 bulb to an E27 fitting? Does the adapter you used have any form of ballast or transformer in? It obviously works, but it seems like you're running a 46v bulb on 220v. Could you please share a little more detail? Thx!!
Reply 2 years ago
Hi there,
I just found this piece of information on amazon from the guy that is actually selling these lamps (https://www.amazon.de/gp/product/B07NBQGPX7/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&th=1). Inside is a transformer 220V > 60V. Unfortunately I can not find the Philips datasheet. Do you have a link?
Kind regards & stay safe,
Erik
Reply 2 years ago
Hi Erik!
Thanks for the AMZN link - coincidentally it looks like someone asked the same question today about the adapter containing a step-down transformer - apparently yes it does!
Here's the datasheet for the Philips bulb: https://www.assets.signify.com/is/content/PhilipsLighting/fp927901104007-pss-global
I just ordered a self-ballasted 110v bulb to make my own box - thanks for being the inspiration!
You too stay safe.
Dave
Reply 2 years ago
was me :)
Reply 2 years ago
Lol - I figured it was too much of a coincidence to not be connected to this project!
2 years ago
Cool idea, but be careful, strong UV light will produce a substantial amount of ozone, which also helps sterilize stuff, but is toxic to breath in. I would suggest opening the box outside after use. Another warning, UV-C does kill the virus, but it is not 100% effective, there's still a fair chance that contaminated objects will be contaminated after zapping it in this box. That's especially true if the object has folds or other places where the light won't reach, such as the folds in those masks. DIY sterilization should only be viewed as a last resort if you absolutely have to reuse a contaminated object.
However, once this whole mess is over, this would be a great way to cure resins, finish SLA 3D prints, or supercharge glow-in-the-dark toys!
Reply 2 years ago
Hi Josh,
that is absolutely true: sterilization of single use equipment is a last resort. And the folds in these masks are really a problem. That is why I recommend turning and sterilizing the items multiple times before you reuse them. There are a lot of people here in Europe that only have one or two masks. And these people are the lucky ones. I read yesterday that some doctors even recommend diy masks made from kitchen paper. The lamp I use is made for medical grade sterilization. It is probably the best you can get on Amazon. In regard to the production of ozone: it is emitted by 185 nm UV-C light. The lamp I suggested has a 185 nm filter, so no ozone is produced. However this is not guaranteed if you use an older lamp. Stay healthy everyone and thank you for your feedback!
2 years ago
I made one of these several years back. Increase the efficiency by simply lining the containers sidewalls and floor with crinkled aluminum foil and support items inside with a cookie rack raised several inches from the bottom. This will help scatter the rays under the item somewhat.
Reply 2 years ago
Thank you for your suggestion. I just added my instructable!
