Introduction: Cakey Brownies :)
This is a very fudgy + cakey brownie recipe which saves me time.
As it is a very quick and simple but definetely worth it recipe that is worth making in your spare time. In less than an hour you can be at home while eating these with friends (i recomend eating alone, personally i like watching series of episodes of shows while eating these)
In less than an hour you can have something that's tasty, delicious and last but not least chocolately, it’s delicate and light. Quick and simple which you will not regret making!
Step 1: Grab Your Ingredients
Ingredients:
- 100ml milk
- 200g granulated suga
- 1 tsp baking soda
- 1 tsp baking powder
- 300g self-raising flour
- 2 eggs
- 90g cocoa
- 1tsp salt
- 30ml oil
Serving:
Tbsp of icing sugar (to taste)
or:
anything that's delicious
Example's:
vanilla ice cream
caramel sauce
some fruit (healthy) like strawberries or bananas
Equipment:
1 mixing bowl or 2 to separate wet and dry mixture
teaspoon
tablespoon
measuring jug
whisk or electric mixer
baking pan
btw tsp = teaspoon
and tbsp = tablespoon for those who don't do cooking as much
Step 2: Add Dry Ingredients
ok so you may have guessed from the title yes
get a preferably large or medium sized bowl and add your:
flour
sugar
cocoa powder
baking soda/powder
and salt
Step 3: Mix
Mix the ingredients in the bowl until they have all combined and it looks like this:
Facts:
coffee For brownies, use strong brewed coffee instead of water to deepen the flavor.
vanilla extract Add in a teaspoon of vanilla
Pudding. Add a small instant pudding box to the mix to add moisture and flavor.
Sour Cream. Add in 1/2 cup sour cream to add a more dense, rich flavor.
Butter. Use melted butter in the place of vegetable oil for richer taste.
Step 4: Eggs
crack in 2 eggs into the dry mixture. also add in your oil as well
eggs are very inportant to add to a cake as it can help the cake create structure, leavening, richness, color, and flavor to it which is good to have in a cake. It also gives the cake strength as well as flour. But sugar helps the cake in taste as it gives tenderness.
Step 5: Mix
Mix your batter until it is dark, gooey and smells chocolately.
use either an electric whisk or beater
or you can also mix with a manual whisk
Tip:
When mixing with a manual whisk stir around the bowl face forward of the mixture and then cut through the middle of the mixture. this will mix it faster.
on electric mix for about 2 - 3 minutes or until combined.
Step 6: Prepare Baking Pan
Tip
Ok so here's a tip you can use which is faster than baking paper
cover the bottom of your pan in foil, when you have covered the base and leave a little bit more for the sides press firmly onto the pan giving your foil the shape of the pan. cut carefully. Turn pan around and pop foil onto pan.
Step 7: Bake
Finally add into the oven
and cook for 40 - 45 minutes. if you are unsure if its baked or not insert a toothpic into the middle. if its clean your good. if not cook for longer. you should be able to press your finger lightly onto the brownies if they spring back its cooked.
Enjoy!
