Introduction: Chess Pawn
In this lesson, you will learn to design a traditional chess pawn!
Let's get started!
Step 1: Let's Get Building!
We need a shape to start with. Let's start building!
Instructions
- Drag a cylinder shape to the workplane.
Step 2: Adjust the Height
Let's adjust the height.
Instructions
- Scale it smaller to a height of 3mm.
Step 3: Add a Workplane
Let's add a new workplane.
Instructions
- Drag a Workplane to the top of the cylinder. (Shortcut = W)
Step 4: Grab Another Shape
Let's add a cone this time.
Instructions
- Drag a cone shape to the top of the cylinder.
- The new shape will land on the workplane you just created.
Step 5: Make It a Bit Shorter
Scale shape to be a bit shorter.
Instructions
- Scale the shape shorter to a height of 11mm.
Step 6: Add a Sphere Shape
Add a sphere shape to the workplane.
Instructions
- Drag a sphere shape to the workplane.
Step 7: Squish It!
Let's make the sphere a little smaller and squish it.
Instructions
- Scale the sphere to a diameter of 18mm.
- Squish it! Scale it shorter to a height of 5mm.
- Move it to the target area in orange.
Step 8: Add Another Cone Shape
Let's add a cone shape.
Instructions
- Drag a cone shape to the workplane.
Step 9: Tweak the Cone
Let's adjust the shape of the cone.
Instructions
- Scale it to a height of 28mm.
- Scale it smaller to a diameter of 14mm.
Step 10: Position the Cone
Let's position the cone.
Instructions
- Move the cone to the target orange area.
- Lift the the cone 3mm off the workplane.
Step 11: Add Another Cone
You will need another cone.
Instructions
- Drag another cone to the target area in orange.
Step 12: Size the Cone
You will need to adjust the size of the cone.
Instructions
- Scale it to a diameter of 12mm.
- Scale it taller to a height of 19mm.
Step 13: Flip the Cone
Rotate and position the cone.
Instructions
- Rotate the cone 180 degrees.
Step 14: Add a New Workplane
Let's move the workplane.
Instructions
- Drag a workplane to the top of the cone. (which is really the bottom of the cone you just flipped)
Step 15: Add a Sphere
Add another sphere to the workplane.
Instructions
Step 16: Size the Sphere
Let's get the sphere sized right.
Instructions
- Scale the sphere to 8x8x8mm.
- Tip: Holding shift on the keyboard will scale the shape in all directions.
Step 17: Reset the Workplane
Let's clear or reset the workplane.
Instructions
- Drag a workplane to the original location of the workplane.
- Tip: Place the workplane anywhere, except on a shape to reset it.
Step 18: Align the Shapes
If you didn't keep everything perfectly aligned, that's ok!
You can align the shapes now.
Instructions
- Select all the shapes.
- Click the Align button on the menu.
- Align the shapes to the middle on the front and side.
Step 19: Group the Shapes
Select all the shapes and group them.
Instructions
- Click the Group button on the menu.
- Tip: You will know if the Group action worked if all the shapes all become the same color.
Step 20: Congratulations
Great Job! You made it!
