Introduction: Easy Chocolate Chip Cookies That Happen to Be Vegan
For a class party, a vegan friend brought freshly baked chocolate chip cookies. Once only gooey crumbs were left, she told the class they were vegan. People looked shocked to find out that vegan cookies could be so delicious. And, when I asked her for the recipe, I found out they were also super easy to make with "normal" ingredients. You won't have to hunt through specialty stores for some obscure ingredients while your stomach is begging for cookies. So even if you’re baking-challenged, and have only a few ingredients in your cupboard, you can easily have a bellyful of cookies in about half an hour. Or, because this recipe does not use eggs, you could safely gobble up a bellyful of cookie dough in even less time!
First, here is a cautionary note:
1) These cookies will look very pale when done compared to normal golden brown chocolate chip cookies. If you do try to achieve that golden color, the cookies will burn and then be flavorless. Don't worry, they will taste great even if they look somewhat peculiar! They are fool-proof as long as you don't leave them in the oven too long.
Step 1: Ingredients and Important Notes
Serves: Approximately 2 dozen (26 teaspoon scoops of dough)
Ingredients:
- 2 1/4 cups unbleached flour
- 2 teaspoons baking powder
- 1/2 teaspoon salt
- 1/2-1 teaspoon cinnamon (optional)
- 3/4-1 cup of vegan chocolate chips
- 3/4 cup raw sugar
- 1/2 cup canola or vegetable oil or vegan margarine, melted and cooled slightly (depending on your preference)
- 1 teaspoon vanilla extract
- 1/2 cup soy milk, vanilla soy milk, almond milk, or water (depending on your preference)
-About the chocolate chips: I used semi-sweet chocolate chips. My vegan friend has told me that many semi-sweet and dark chocolate chips in baking aisles are vegan. Just make sure to check the ingredients because many popular baking chips do have milk fat. You could also use carob chips, but I know fewer people prefer those to semi-sweet or dark chocolate chips. You could also skip the chips. I actually prefer chip-less cookies, and know that these cookies are also delicious without the chips!
Cooking Supplies:
- large bowl
- medium bowl
- measuring cup
- measuring spoons
- whisk or silicon spatula (for mixing)
- baking sheets
- oven mitt
Bake time: 9-15 minutes; will vary depending on your oven. My oven takes 12 minutes to bake these cookies.
-Why I use a silicon spatula: I use a silicon spatula because it mixes the liquid ingredients and dry ingredients even better than a whisk with this particular recipe. If you only have a whisk, that is fine, but the dough might get caught and you will have to constantly pick it out. If you only have a whisk, I could recommend using your hands.
Read before starting:
-Do not grease the baking sheet. There is enough oil in the batter.
-It is ideal that the ingredients are room temperature for baking, but it's not necessary.
-Do not put the cookie sheets on the stove while the oven is hot. This will cause the sheets to heat, and the cookies will bake unevenly.
-These cookies do not spread much while baking, so feel free to place them close together on the baking sheet.
-Do not leave them in too long. These cookies will come out soft, but they will harden when they cool. Because they come out soft, a friend told me she has accidentally burnt them before.
-Lastly, always remember to have your oven mitt handy.
Step 2: Mix the Dry
Preheat oven to 350 degrees Fahrenheit.
Then, in a large bowl, mix:
- 2 1/4 cups flour
- 1/2 teaspoon salt
- What-ever-makes-you-happy cups of chocolate chips (I add them in at this point because it feels less laborious once the dough gets thicker and stickier when the dry and wet are combined. Sometimes I don't even add chips to this recipe!)
If you REALLY like cinnamon, add the full teaspoon. If you'd like a milder flavor do 1/2 teaspoon.
Make a well in the center of the dry ingredients and set the bowl aside.
-Why did this hole in the middle?
Later, you will be pouring the wet ingredient into this hole. Digging this hole in the middle of the ingredients will make enveloping the wet ingredients with the dry ingredients later much easier.
Step 3: Mix Wet Ingredients With Sugar
In a medium size bowl whisk together:
- 3/4 cup vegan sugar
- 1/2 cup canola or vegetable oil or vegan margarine (depending on your preference)
Tip: If you want your cookies more cake-like, add a little bit more liquid (i.e., more soy milk, almond milk, or water).
Step 4: Pour Wet Into Dry
Pour the wet ingredients into the hole you made earlier in the dry ingredient's bowl.
Mix it well with a spatula, but do not overwork the dough. Not overworking the dough means it will not get too thin.
Tip: Remember to scrape the bottom of the bowl for dry ingredients you might miss.
Step 5: Spoon Dough Onto Baking Sheets
Spoon dough onto ungreased cookie sheets in tablespoon scoops.
Step 6: Bake the Cookies
Bake the cookies at 350 F for 10-18 minutes. It will all depend on your oven!
Step 7: How to Tell the Cookies Are Done
They don't get very dark unless you use brown sugar, but will get a little brown on the very tops and bottoms.
The cookies are done when they seem a little bit softer than you would want them to be. They will significantly harden up once they cool.
If they do not look done, check the cookies every 2 minutes until they are to your liking.
Step 8:
Step 9: Take Them Out of Oven
Once the cookies are done baking, take the sheets out, one at a time, using your oven mitts. Set the sheets on a stable counter.
Move the cookies onto wire cooling racks with a spatula.
If you do not have a wire cooling rack, like myself, you can use wooden cutting boards.
I decided to use wooden cutting boards because wood is not a good conductor of heat. The method has worked just fine.
Note: If the cookies start to crumble when you to begin to transfer them to the cooling rack or wooden cutting board, let them sit on the sheet for 2 more minutes
Step 10: Enjoy!
Lastly, make sure you get someone to wash the dishes, because you'll be busy eating the cruelty-free sweets of your labor.
149 Comments
7 years ago
Use brown sugar instead of raw and then add 1/2 cup of Apple sauce for a color taste and texture fix
7 years ago
I used pumpkin puree instead of oil, coconut sugar and brown rice flour and they turned out PERFECT. Thank you for this easily tweakable recipe. :3
Reply 4 years ago
that`s sound great can you share the recipe ? how much pompkin pureee do we need ?
Question 4 years ago
how long can I keep it ?
I would like to use water instead of Soy but would taste different ?
Sako
6 years ago
I made it and my family really like cookies.
6 years ago
Great recipe! I used Molasses Unrefined Sugar for depth of colour, olive oil and gluten free flour. They are awesome, dark brown and a slight caramel flavor.
6 years ago
I made these last night. The only thing I changed was to sub 1/4 cup of sugar with brown sugar. Thought it would impart flavor and color. They came out like bland bread biscuits with chocolate chips. :(
6 years ago
I made most of my doughballs smaller than usual. This gave me enough for 24 small cookies and about 6 "normal" sized ones. The small ones did not flatten when baked the way I am accustomed to with cookie dough. The changes I made were: 5/8 cup sugar, +2 tsp chocolate powder. Compared to other cookie dough recipes, I find this recipe a bit on the dry side. For health-conscious people (as many vegans are), you might also find this recipe overly sweet. Still very tasty comfort food.
6 years ago
Question:
Step 2 has a picture of you pouring the chocolate chips into the dry ingredients however you said to add the chocolate chips once the dough has been worked thoroughly. Which one is correct?
Reply 6 years ago
Thank you for noticing that! I just updated considering the confusion. I personally like to add them with the dry because it's less work than combining them later on. But, I also don't like chocolate chip so I often leave them out completely.
6 years ago
I made this recipe, and I LOVE IT! Thank you for you you and your friend to share this :3
7 years ago
The texture did end up being almost raw feeling for me...still tasted good so I'm not complaining!
7 years ago
I just made these cookies and they were amazing! I made a couple changes to the original recipe after looking at some comments. Used brown sugar instead of the raw sugar, I poured in some hemp seeds for some more healthiness and you can't see or taste them! I also flattened the cookies slightly. These cookies taste best right out of the oven.
7 years ago
I just made these. They tasted a bit bland. Any tips?
7 years ago
Ingredient mixing instructions? Baking temperature?
Reply 7 years ago
http://youtu.be/ldD0efCfNvM
7 years ago
I would not make these again. I brought them to a holiday party potluck, and they were not good. The complaints that others have in the comments are all accurate; pale, cakey, not such good flavor. People at the party were not impressed. It was definitely not a good thing when facing the increased scrutiny of bringing a vegan dessert in the first place.
Reply 7 years ago
Hope you didn't get the salt and sugar mix up.
Reply 7 years ago
Mine have always been a big hit with everone. Maybe it's your technique that's all wrong. Could you have overworked the dough?
