Introduction: Christmas Light Installation for Vinyl Windows
After years of hanging our Christmas lights on the vinyl windows in my home I have found a great way to install them.
Step 1: Supplies
You will need a few supplies,
1. A tape measure (not pictured here).
2. ½ inch Scotch double sided tape.
3. Metal shears or Hacksaw.
4. Plastic panel end cap molding.
The plastic trim molding for vinyl wall panels. can be found at Home Depot. It comes in 8’ lengths.
Step 2: Vinyl Wall Panel Molding
Measure your window length and width and cut your trim pieces. I tend to cut them short on the corners to make the installation easier.
Step 3: Tape
Put the tape on the back of the trim and attach them to the glass right up against the vinyl frame.
Step 4: Trim
You can cut the trim around the locks.
Step 5: Installation
Install the lights by pushing the wire into the molding.
Starting at the bottom right or left corner, working your way up to the top of the windows. Then across the bottom of the top window then down and across the top of the bottom window, then down again working your way around the window. Use a wooden dowel to push the wire in this will save your fingers.
Step 6: Enjoy!
This molding does not interfere with the operation of the window once the lights are removed. The lights are easily removed by simply pull the light string out. These can be used year round for all holidays!
