Clear Sink Clog - FAST, NO BUCKETS, NO CHEMICALS
Intro: Clear Sink Clog - FAST, NO BUCKETS, NO CHEMICALS
So, the bathroom sink is clogged again. I hate it when that happens. Here is the fastest, simplest, tidiest way to get rid of this little inconvenience.
The web is FULL of references and guidance on clog-removal methods that involve disassembly of pipes, or evil liquids of one sort or another. We are going to AVOID all that yuck and mess, and get right to the heart of the matter.
Most of the time, the clog is a combination of hair and slime, and it is NOT at the bottom of the trap. (That's the plumbing term for that removable U-shaped pipe at the bottom.) Slime and hair collect in the drainpipe right where the stopper-lift lever intrudes into the drainpipe. We are simply going to pull out the stopper-lift lever, scrape the clog loose, and flush it on down the drain. No muss, no fuss, no wrenches, no Nasty Potions. You don't even have to SEE the foreign life form.
(BY THE WAY, since you are an insightful and proactive person, you will perform this procedure BEFORE the drain is TOTALLY clogged. Letting the water seep out, even if it takes a while, allows you to do the job without a bucket.)
All you need is a short length of 1" PVC pipe to use as a scraper. This handy tool will work EVERY time, for the rest of your house-keeping life.
If you are the Do-it-Yourself type of person, you may already have some 1" plastic pipe left over from some other project. You can certainly get it at most hardware stores or home centers. If you prefer the online-commerce approach, as many do, a modest $5 PayPal transaction to your author will bring one to your door.
STEP 1: The Region of Goo
OK, kids, this is where it's happening - the spot where the stopper-lifting rod intrudes into the drainpipe. In my experience, there's usually some hair hanging over the rod, in combination with some gooey bio-slime. All we need to do here is pull out the stopper and the lifter rod, give the glop a shove in the right direction, and flush it away.
STEP 2: Remove the Lifting Rod
Undo the lifting rod nut by turning it CLOCKWISE. It seems counter-intuitive, but the standard "righty-tighty, lefty loosie" would only apply if you were facing this assembly from the back side.
After the nut's off, simply pull out the lifting rod. If you were proactive enough to take care of this job before the sink was TOTALLY clogged, nothing will come out except a wee ball of slime. If you ARE in deep water, better have a bucket handy.
After the lifting rod is out, you can pull the stopper out of the drain pipe. Yes, the bottom leg of the stopper is likely to be covered in slime, which you can remove with your finger or an old toothbrush. (Not your housemate's.)
STEP 3: Scrape That Clog Right Out of Your Life!
Ok, even though we've removed the hardware that passes through the Region of Goo, that ol' slime ball is probably still hanging in there. This is where our PVC* push-pipe comes in handy. Introduce the pipe into the drain, and push down. You will possibly feel some resistance at first. The Goo will resist a wee bit, but you are far mightier.
It's a good idea to scrape multiple times, getting all sides of the drainpipe.
*If you don't have a length of plastic pipe handy, some other solid item with a small-enough curved edge will do. In a pinch, I have been known to use a length of wooden quarter round trim.
STEP 4: Ready, Set, FLOOSH!
OK, almost done. Now that the clog is scraped loose, all you have to do is open the faucet and let the water flush it down the drain.
Oh, yes, it is VERY smart to seal the opening where the lift rod was located. Perhaps your finger or thumb is large enough to cover it. (If not, improvise with a wad of bath tissue.)
VICTORY! Goo-Be-Gone! Well done. Nothing left to do but reassemble.
STEP 5: Reassembly
If you've gotten this far, reassembly should be easy.
- Remove any improvised item used to block the lift-rod opening.
- Push the lifting rod back into its opening.
- Reattach the lift-nut by turning it counter-clockwise.
- Wash your hands, and treat yourself to a fine beverage.
71 Comments
RicksterInstructables 5 years ago
When you reinstall the lifter rod, it has to pass through the hole in the tab at the bottom of the drain plug.
Put the stopper in the sink, with the tab towards the “back”.
Then insert the lifter rod with it angled slightly downwards (as if the sink handle for it is pulled up a bit.)
Wiggle the sink drain handle to ensure correct operation, then tighten the nut holding the lifter ball joint into the drain. Don’t overtighten.
NOTE:
I myself, would never shove clog like material down the drain. That’s just asking for more complex problems that might/will require a plumber.
Warning. Serious grossness factor.
There is undoubtedly a large bundle of slimy, smelly disgusting hair caught on the lifter rod.
In my family, due to the grossness factor, this is a definite “dad” thing, (though my hair is not the culprit).
Find a way to lift the huge ball of slimy hair out of the drain.
I do it before removing the lifter or stopper.
Amazon, Home Depot etc. sell these very inexpensive plastic things that are just a thin strip of plastic with “teeth” on the sides. Search “drain zip”.
Slide it into the drain alongside the stopper and lift it out. Be prepared to say “ewww” as you remove it with all the slimy biofilm caught in the teeth.
After getting the majority out, then remove the lifter and stopper as explained in this Instructable.
obillo 6 years ago
Who's got a solution for BATHTUB drains?
MisterHighway 5 years ago
vivienevolves 6 years ago
Pull the overflow cover off the tub (the thing the water goes down if someone tries to overfill the tub) and use any of the methods you like but applying them through the overflow. Oh and it is the gas that is produced that makes the vinegar/baking soda work - the trick is getting the baking soda to the bottom of the trap before adding vinegar - I add a small bit of hot water after the baking soda and before the vinegar to make the reaction happen where it helps. Oh - and if long hair is your problem, save yourself the headaches and get a screen trap to replace the sink/tub plug for the 90% of the time you don't want the basin to fill. Teenagers can be taught to clean the screen after every shower by giving them the joy of cleaning hair out of one drain themselves. A Mom.
nehmo 6 years ago
I woke up, went to the washroom, discovered the sink was partially clogged, immediately used this method to unclog the trap, used the sink to wash up, and went into the kitchen. There, I met my wife and her sister. Apparently, her sister had dropped her diamond engagement ring down the sink. They were waiting for me to wake up so I could retrieve it for her.
rnshagam 6 years ago
Sorry for her loss--but perhaps they should have left a note/post-it in the sink?
MikeH158 5 years ago
So I went to Lowes Hardware store, and bought a sheet of rubber plumbing gasket material.
Cut a circle of it to fit inside threaded lift-rod nut, install, and it seals against water leak so I can reach up and turn on/off water
gcai_fwb 5 years ago
doo da do 7 years ago
Put hot water in the drain, put two or three Alka seltzer in the drain, use the stopper, then fill sink with hot water, in a few minutes open stopper and it will be good to go. Doodado worked for me many times
AndrewA167 5 years ago
First I pull the stopper, then dump about a cup of baking soda down the drain, then follow it with a healthy dose of white vinegar. Stuff a rag in it, and let it sit for 30 minutes or so. In the meantime, I boil some water in a teakettle. Then after the 30 minutes go by, I pull the rag out and pour the boiling water down the drain. Clears it completely every single time.
I used to take the plumbing completely apart to get things really clean, but that gets old really fast. I'll only do that now if nothing else works (including snaking it). But usually, baking soda, vinegar, and boiling water do the trick.
lassensurf 6 years ago
Rocket Girl is correct. Baking soda and vinegar are weak in themselves and so is their bubbling/agitating action. Mixing the two together only gets you some inert ingredients that do nothing.
HOWEVER!!!! If you have a bad clog, and can seal the opening to the drain very quickly after dumping in the second ingredient, what CAN sometimes happen is the air/gas/CO2 being formed and expanding can "Push" the clog through with the gas-pressure, but this takes some good strength to really press down on the drain plug to make sure it doesn't just fizz back up the way it came.
Is cool when it works, but doesn't always work, and is hard to do. Otherwise, don't use baking soda and vinegar/citric acid together to clean anything, it doesn't work. One or the other as a very MILD MILD MILD cleaning agent, but not both.
Drake88 7 years ago
Vinegar and baking soda works too. The vinegar is slightly acidic which can help cut through any soap goo. If you use Cider Vinegar, the room the sink is in will smell like Cider Vinegar for a day or so too, which isn't a bad smell(and it may also help cover any smell of the goo should it be stinky).
Rocket Girl In Training 6 years ago
Vinegar isn't acidic after you put baking soda in it. How about just vinegar?
wabpita 6 years ago
I guess you have never tried the baking soda and vinegar method. When you pour both into the drain, usually the baking soda first. A chemical reaction starts and it "boils" up and you can even hear it working. Follow by running hot water.
rkrishnan7 6 years ago
All of the acid and base will not come into contact and react instantly; The proliferation of bubbles will agitate the mixture in the confined space and both un-neutralized acid and base will come into intimate contact with the goo, so each can do it's own thing. Just my 2c.
charles543 6 years ago
We already know all of that. Wabpita was talking figuratively about boiling because it is a physically similar type action. I'm sure everyone else understood that. The mechanical action could help loosen the clog.
wabpita 6 years ago
I also looked up baking soda and vinegar to find the information that rocket girl in training was spouting and did not find any reference to her analysis. Did find many references as to the ability of the soda and vinegar to open a clogged drain.
