Introduction: Cobra Weave Exploding Stick Bomb
The Cobra Weave Exploding Stick Bomb is pretty dang cool. I've seen a lot of the smaller stick bombs on Instructables but none of these chain ones so I'm really excited to share it with everyone.
The chain is pretty easy to put together and is reusable so there is plenty of entertainment value. It's awesome to watch the stick bomb in action, rising like a cobra and noisily spitting sticks out as it goes. Watch the video to see it in action!
I would love to see other people's cobra weave stick bombs so if you make a cool one be sure to link in the comments.
Step 1: Materials
What you need:
-a big ol' pile of popsicle sticks
-string (optional)
-your hands and maybe a buddy's hands too
Step 2:
Cross two sticks into an "x" shape like in the picture. You want it to be a little slantly so that there are two obtuse and two acute angles. The stick on top will be stick 1 and the stick on bottom will be stick 2, see picture for note.
If using two colors, these first two stick should be the same color, in my case green.
Step 3:
Add a Stick 3 by tucking one end under the end of Stick 2. The new stick should go over Stick 1.
If using two colors then the stick added in this step should be the other color not used in the previous step, purple in my case.
Step 4:
Add another stick by tucking it's end under Stick 2 and letting the rest lay over Stick 3.
If using two colors then add a stick the color of the ones you used to make the "x" shape, in my case green.
Step 5:
Continue adding sticks by tucking the end under the opposite color stick and letting the rest go over the other stick until you've reached the desired length. Just remember that patiece will pay off and the longer the stick bomb you make the longer explosion show you'll have.
Step 6:
If you want to be able to trigger the stick bomb from a distance then you can attach a pull string. Simply tie a piece of string to a stick then use that to bind the working end.
If you don't want the pull string then just add a stick so that it is under both ends but over the middle stick, as the picture shows.
Step 7:
When for the action, give the pull string a nice tug or remove the binding stick by hand and stand back. If all goes well your cobra weave should rise up like a wave while sticks are wildly thrown across the room. Enjoy!
