Collect Rain Water With a Wine Barrel
Intro: Collect Rain Water With a Wine Barrel
I think I read all instructables on this site about collecting rain water.
Finally I've decided to build my own one with a wine barrel because I didn't want to destroy the look of my future-to-be terrace. I always found rain water collectors super ugly. It's usually an old plastic tank or barrel; handy but not very nice to the eye (and I didn't have the motivation to build something like this to hide it.
Anyway, here's how I did it.
Material
- a wine barrel (found on eBay for 50 EUR) - make sure to get one with a lid and a cork (usually it's a special cork located in the belly part of the barrel)
- a rain water collector to hook up to the gutter (found on eBay for 19 EUR - but otherwise available in nearly all DIY shop) - I choose that model because the collected water would come out via a little tube and not an "open-air" half-pipe
- driller
- flat wood drill heads
- some screws
- an old piece of board about the length of the barrel's lid
- a handle
Material
- driller
- some screws
- a handle
STEP 1: Prepare the Barrel's Lid
Usually wine barrel's lids are a bit wobbly.
They are made of some planks inserted in each other, and are supposed to be inserted in a groove at the top, inside the barrel. Because of that I had to make the lid stronger so it would resist to frequent usage.
I found an old piece of wood board in my garage and screwed it tight at the back of the lid. I made sure to use rustproof (inox) screws. In order to be able to close the barrel and properly put the lid back on, (and because the lid is round) I had to saw the 4 corners of the board as you can see on the picture.
Last year we bought a new kitchen and we received two extra handles (don't ask me why), so I've decided to use one of them for my barrel.
The screws that came with the handle weren't long enough to go through the thickness of the lid + the board attached at the back. So I used a flat drill head to make a wider hole and reduce the thickness so I could properly attach the handle.
Make sure to place the handle in the middle of the lid, it's not only more beautiful but also easier to manipulate when you open/close the barrel.
STEP 2: Connect the Rain Water Collector on the Gutter
I followed the instructions that came with the PVC rain water collector (rwc) to hook it up to one of my gutter. It was super easy, I just had to saw a section of 8cm off the gutter at the right height and insert the collector.
IMPORTANT! In order to have an overflow and avoid my barrel to be overfilled, I installed the rwc a bit lower than the top of the barrel. Therefore the water in the barrel can't go higher than the height on the gutter where the water is collected.
I drilled a large hole with the wood flat drill head, inserted the transparent tube that came with the rwc then used silicon (same as for a shower tub or bath) to sealed it and make it water proof so the water could flow back via the tube should it reach a certain level in the barrel.
STEP 3: Here Comes the Rain
Within one week my barrel was full to the top (I was even surprised to get so much water in just a week). I now use it to water my plants, flowers, to wash my terrace etc...
There's still a little bit of wine smell when you open the barrel, but that's more a positive point than a negative one ;-)
20 Comments
dincrecords 2 years ago
Ozy Mort 4 years ago
water off my roof for the sole purpose of watering plants in my Garden. I'm
based in Sydney Australia which you may know is experiencing drought and
unprecedented bush fire. Whilst we're in drought we are getting some rain
usually in large and quick amounts. In half an hour I can fill the barrel
enough for 2 weeks. My problem is after a short time the water smells of bad
eggs. The plants like it and the PH at 6.5 is good. Have you any ideas how I can
rid myself of the smell. Regards, David
SHOE0007 6 years ago
You know besides activated carbon you could place large amounts of zinc or copper metal (Not the salt) the metal. It would work quite well to reduce the harmful bacteria that may be growing in the water. Since you are putting it into the garden their is a risk (small) of pathogenic bacteria and fungi growing on your crop. This could really help. Another option is silver metal (Silver plated copper) but it may be very expensive.
mkrueger7 9 years ago
TheTunaMan 11 years ago
didgitalpunk 12 years ago
chouf 12 years ago
sunshiine 13 years ago
bgmd 13 years ago
chouf 13 years ago
i'm not a "barrel expert", but as far as I know, i think you'll have to remove or loosen the top metal band in order to be able to push a little bit the planks aside so the top can come off its groove.
the way it works now with my barrel is that the lid is no longer in the groove, but on top of it (see my drawing on imagehsackhere). Personally the top came off quick easily, I only had to loosen a bit the metal band (I used a flat screw driver and a hammer to tap the band up)
hope this helps
Rocksterr 14 years ago
chouf 14 years ago
Grady 14 years ago
PS118 14 years ago
chouf 14 years ago
BeWaterWise Rep 14 years ago
Ninzerbean 14 years ago
Weissensteinburg 14 years ago
chouf 14 years ago
