Continuity Tester (Using Android Phone)
Intro: Continuity Tester (Using Android Phone)
Continuity tester using android phone
Requirements:
1.Android Phone
2. 3.5mm jack or old headphone with mic
3. wire (multimeter probes is better)
4.Application
STEP 1: Cut the Headphone
STEP 2: Find the MIC and GND Wires
STEP 3: Connect 3K Resistor Parallel to the MIC and GND
Connect 3K resistor parallel to the MIC and GND and connect the probes wire and solder it.
STEP 4: Finally Insulate the Wires
STEP 5: Install Application to the Phone
https://play.google.com/store/apps/details?id=com.topstarcreations.continuitytester
STEP 6: Testing.
https://www.youtube.com/watch?v=djYh4hbMTLo
18 Comments
stateit 7 years ago
tsaltzman 7 years ago
topstarcreations 7 years ago
Don't check the charged components. no fusing.
TFOzkorucuklu 7 years ago
Cool project. I really want to do but I can't do it now, because my phone had died. :/
V4NZ777 7 years ago
you probably tested a condutor with voltage
BuhlMan 7 years ago
eagas 7 years ago
Mjtrinihobby 7 years ago
ironsmiter 7 years ago
something like this ?
I have multimeters in just about every tool box, and car (at least 6 or 7, spread about), but my smartphone is almost always on my hip. Between datalogging, and reduction in size, I am right there with you, in the "can't wait" group.
hooray!
thank you sir.
DIY Hacks and How Tos 7 years ago
Great idea! Having a continuity tester in your phone is much better than having to carrying around a multimeter all the time.
thank you sir.
ccray1954 7 years ago
what watt or volts are the 3k ohm resistor?
across the resistance below 0.5V
i like this and need one for my ground to antenna checking continuity...excellent might try to make myself...
Antzy Carmasaic 7 years ago
I will surely add a warning.
