Control Servo With Light
56,679
48
13
Introduction: Control Servo With Light
Hello!
In this Instructable i will teach you how to control a servo using a Photocell.
This is very simple and good for beginners.
Step 1: Materials
1 x Photocell
1 x 10k Resistor
1 x Arduino
1x Breadboard
1x Servo
and some jumpers
Step 2: Wiring It Up
Wire everything following the schematic below.
Step 3: The Code
The Code is very simple:
#include <Servo.h>
Servo myservo;
int val;
void setup()
myservo.attach(12);
void loop()
val = analogRead(0);
val = map(val, 0, 1023, 0, 179);
myservo.write(val);
delay(15);
3rd Epilog Challenge
13 Comments
4 years ago
hello can you tell me if this code will work on the arduino nano thanks for your time .
Reply 2 years ago
Does it work ? Did you try ?
4 years ago
Could please tell if this code will work on the Arduino nano?waiting for your reply
Reply 2 years ago
5 years ago
can someone help me out for using two servo (dual axis) with this ?
I tried with modifying this code but ended with horizontal axis motor not showing response! vertical axis worked fine
5 years ago
Hello other coders. my name is Bill Dawall. I need help with the code. If any of you fine young men and women would like to help please reply.
5 years ago
please give me advise.Now I research about dual axis solar tracker.Can anyone help me to give source code?
5 years ago
pls i need assistance on my project, i am quite new on this stuff; using LDR to controlling a non continuos servo motor & print, 'welcome' when the motor rotate 180° left & 'goodbye' when the servo rotate otherwise
6 years ago
Hi! I am new in all of this. I cannot get the wiring. Has anybody got a pics of this project? Thanks.
6 years ago
6 years ago on Introduction
is it c c+ or c++
7 years ago on Introduction
Hi, I am surprised that after 3 years that no one has had any problems with this project.
The risk is that the 5V supply from the arduino is not able to supply enough current to a servo, if you want to drive anything with the servo you may have problems, such as jittering of the servo or resetting of the arduino.
The servo should have its own power supply.
This is a nice comment to those who are aiming to try this out, that you run risks of overloading the arduino 5V regulator.
TomGeorge
11 years ago on Introduction
Thank you for this informative post! I wanted to know what type of servo you used? Would it be possible to purchase an rc servo and control the spinning amount? For example, say I would like it to turn 1/4 of the way only instead of full revolution can this be done using your instructions or would there be some modifications that would need to be made?
Thanks again!
