Introduction: Convert 12V DC to 5V DC
Hii friend,
Today I am going to tell you how to convert upto 24V DC to constant 5V DC.
Let's get started,
Step 1: Take All Components As Shown Below and in Pictures
Components required -
(1.)Voltage regulator - 7805
(2.)Multimeter (Digital/Analog) [Only for Testing purpose]
(3.)Input power supply - 7V.........24V DC
Step 2: Connect Input Power Supply
7805 voltage regulator contain three pins.In which we have to give power supply on pin-1 and pin-2.
we have to connect +ve input power supply to the 1st pin of the voltage regulator and -ve input power supply to the 2nd pin of the voltage regulator as shown in the picture.
Step 3: Output Power Supply
Now we have to connect output power supply wires.The output power supply will give always constant 5V DC power supply.
we have to connect the +ve wire of output power supply to the 3rd pin of the voltage regulator and -ve power supply to the 2nd pin of the voltage regulator.
Step 4: Wiring Is Completed
Now the wiring of voltage regulator is fully completed and the next step is we have to check the circuit.
we have to give input power supply about 7V..........24V DC and we will get constant output power supply 5V DC.
Let's check,
Step 5: Checking
In this circuit I give 12V DC input power supply and as you can see in the display digital multi meter the output power supply is almost near about 5V DC.
This type we can convert upto 24V input DC to constant 5V output DC.
Thanks
14 Comments
Question 2 years ago on Introduction
i have a battery that gives 13.4 volts, i want 10.8 volts, wich diffuser should i use?
3 years ago
In addition to the decoupling capacitors, this needs to be on a HEATSINK or the regulator will overheat and fail if you try to draw any appreciable power. This instructable is half baked misleading and inaccurate.
Reply 2 years ago
Yes.
Totally incomplete
Tip 3 years ago on Introduction
Please do not follow the instructions in this guide. You MUST use decoupling capacitors on both the input an output of a regulator for proper operation.
Reply 2 years ago
What happens if you don't use the capacitors? I'm just curious
Reply 2 years ago
I've done many of this.
Your phone will charge backwards
12 V dv convert into 5V dc can we use as mobile charger?
Answer 2 years ago
Yes this works great as a mobile phone charger. Simply get a USB extender cable and cut it in half. Use the red and black wires. Make sure you thoroghly test the final circuit before plugging in your phone!
2 years ago
How many mA can I pull out of this (with those coupling capacitors)
2 years ago
Thanks pal @ Baldengineer..
3 years ago
Baldengineer knows what he is talking about. The LM7805 needs the capacitors listed in the datasheet to have stable enough voltage for most components. Look at his guide. https://www.baldengineer.com/regulator-basics.html
3 years ago
Only it can be used in batteries power supply because there will not be fluctuations frequency.
Reply 3 years ago
I am sorry, but that reason is incorrect. You absolutely do need to use decoupling capacitors. Capacitors on the regulator's input will help extend the operational life of the battery. Batteries have a very high ESR and various current draws will shorten their operational life. (For rechargeable batteries, this means shorting their total operational life.)
The output of the regulator needs, at the least, small decoupling capacitors to react to (relatively) high frequency changes by the load. No linear regulator is stable without output decoupling capacitors.
Please update your article so that uninformed users are not mislead by incorrect circuit design.
3 years ago
Thank you for the mention! You are absolutely correct. This design needs the decoupling capacitors. At the very least, they need the values recommended in the 7805's datasheet.
