Introduction: Credit Card Sized Deauther With Oled Screen
Fellow Secret Agents, here you have a Deauther: a very useful tool to keep in your pocket, maybe one day you need to disable a security camera, or a drone, or broadcast an emergency message....
Be aware of the legal implication: please use this tool responsibly and do not use it against others without their permission.
Step 1: Components
Total less than 5$:
- NodeMCU clone
- OLED 0,96 inch price
AMS1117 not really necessary since you can power from VIn (5V to 9V)
Recycled comonents:
- USB cable (a broken one)
- Cables (from broken LAN cable for rigidity)
- 3 push-buttons (from old circuit)
- Epoxidic glue (few drops)
- Magnet
- Credit card
Step 2: The Code
This project is only a iteration of the great original from spacehuhn:
https://github.com/spacehuhn/esp8266_deauther
You can find several tutorial in internet, showing all the possibles way to upload the code.
Anyway in my opinion uploading using nodeMCU-flasher is the simplest option:
https://www.hackster.io/timbenmillard04/nodemcu-wi...
Once you uploaded the code, you should be able to connect to the NodeMCU and activate the screen......
Step 3: The Circuit
As simple as detailed in the images.
You can connect ground to any of the ground pins.
There are several option to how to power the board: Usb , VIn pin, 3,3V.
Step 4: Glue It Together and Go
Please keep in mind that when you are connected remotely to the board the screen does not work.
Get a computer, phone or tablet and scan for the WiFi network pwned. Connect it with the password deauther.
Once connected go to the ip 192.168.4.1. It may take a minute to load for the first time. You will see a web interface, and you'll need to read and accept the agreements.
Enjoy
![Pocket Sized Contest](https://content.instructables.com/FKX/PU8Q/JSPAAZCJ/FKXPU8QJSPAAZCJ.jpg?auto=webp&frame=1&width=320)
