Introduction: Cup - Jar - Mug Cozy
I use glass jars in my family's lunch boxes. In order to protect them from clanking together & breaking, I crochet cozies. I could just make simple sleeves, but I like to personalize them. My daughter loves ducks, my husband is a big Star Wars fan & my son loves mice.
I've made these to go over mugs, baby bottles & baby cups. This pattern can be adjusted to fit any cylindrical item. You just need only to alter the the starting round to fit the size you need.
(This project requires you have a basic knowledge of crochet)
CROCHET ABBREVIATIONS:
- CH - Chain
- SC - Single Crochet
- HDC - Half
- TR - Triple Crochet
- SS- Slip stitch
MATERIALS:
- Cup or Jar or Mug (or baby bottle or ?)
- G (4mm) crochet hook
- Yarn in YELLOW, ORANGE,WHITE, BLUE for Duckling
- Yarn in GREEN, TAN, WHITE for Baby Y
- Scissor
- Yarn needle
Step 1: DUCKLING DIRECTIONS
This pattern calls for chain 25 to start to fit around a jelly jar. If 25 stitches is not the correct size based on your mug/ cup /jar size,, then chain an even number accordingly.
DUCK FEET:
Using ORANGE Yarn
Round 1: CH 25, SS into first stitch to form a circle, be careful not to twist your chain
Round 2: CH 1, sc around, SS to join
Cut yarn & weave in ends
DUCK BODY:Change to YELLOW
Rounds 3 - 5: Ch2, in 1st stitch from previous round HDC around, SS to join
Round 6: Ch 1, SC around, SS to join.
DUCK BILL: (Make 2)
Using ORANGE Yarn
ROW 1: CH 6
ROW 2: Skip first stitch, SC in next 5 stitches
ROW 3: CH 1, 2SC in same stitch, SC in next 3 stitches, 2SC in same stitch
ROWS 4 & 5: CH 1, Skip first stitch, SC in 7 stitches
Leave a tail to use to sew the bill to the body.
DUCK FEET: (Make 2)
Using ORANGE Yarn
ROW 1: CH 6
ROWS 4 & 5: CH 1, Skip first stitch, SC in 7 stitches Cut yarn & weave in ends
ROW 6: CH 1, 1 TR, SS into next CH, 2 TR, SS into next CH, 2 TR, SC into same CH as last TR
Leave a tail to use to sew the feet to the body.
DUCK WING FEATHERS: (Make 2)
Using YELLOW Yarn
ROW 1: CH 6
DUCK EYES: (Make 2)
Using BLUE Yarn
CH 4, SS
ROUND 1: Ch 1, 6 sc into center of the loop created, SS(6 ST)
ROUND 2: CH 1, SC in same space as CH, 2 SC in each ST, SS (12 ST)
Using WHITE Yarn
ROUND 3: Attch yarn using SS in any CH CH 1, SC in same space as CH, * 2 SC in next ST, 1 SC * Repeat from *to * SS (18 ST)
Leave a tail to use to sew the eyes to the body.
Step 2: PUTTING THE DUCKLING TOGETHER
I like to put the body on the jar & then position & pin all the pieces in place. I remove the body from the cup- jar - mug & sew everything on.
EYES:
- Place the body onto the cup - jar -mug.
- Using your yarn needle & compatible colored yarn stitch the eyes to the front of the body.
- Place them so the top of the eyes are even with the top of the head, or slightly higher.
- Sew them so that the outer edges of each eye touch each other
DUCK BILL:
- Using your yarn needle & compatible colored yarn stitch the bill to the front of the body.
- Place one as the upper bill. Place it directly below the eyes.
- Sew the second one directly below the first bill.
DUCK WINGS:
- Place the duck body back on your cup - jar -mug.
- Position the wings so that they are evenly placed on either side of the body.
- You might want to safety pin them on.
- Remove the body from the cup - jar -mug.
- Using your yarn needle & compatible colored yarn stitch the wings to the side of the body.
Step 3: BABY Y DIRECTIONS
If 25 stitches is not the correct size based on your mug/ cup /jar size, then chain an even number accordingly.
FEET:
Using GREEN Yarn
BODY:
Change to BROWN
Round 3: CH 1, sc around, SS to join
Rounds 4 - 5: Ch 2, in 1st stitch from previous round HDC around, SS to join
COLLAR:
Change to WHITE
Rounds 6: Ch 2, in 1st stitch from previous round HDC around, SS to join
HEAD:
Change to GREEN
Rounds 7 - 9: Ch 2, in 1st stitch from previous round, HDC around, SS to join
EARS: (Make 2)
CH 3
ROW 1 – In 2nd chain from hook, 2 sc ( 2 ST)
ROW 2 – CH 1, sc 2
ROW 3 – CH 1, 2 SC in each ST (4 ST)
ROW 4 – CH 1, 4 sc
ROW 5 – CH 1, 2 SC in each ST (6 ST)
ROW 6 – 6 sc 6
ROW 7 – CH 1, 2 SC in each ST (8 ST)
ROWS 8 – 10 CH 1 , 8sc
After ROW 10 SS the first & last ST together to form a cone shape.
Leave a tail to use to sew the ears to the body.
EYES: (Make 2)
Using BLACK Yarn
CH 4, SS
ADDING THE EARS & EYES:
I like to put the body on the jar & then position & pin all the pieces in place. I remove the body from the jar & sew everything on.
Using your yarn needle & the yarn you left as a tail, stitch the eyes to the front of the body.
Using your yarn needle & the yarn you left as a tail, stitch the ears to the either side of the body.
