Cutting (floor) Board
Intro: Cutting (floor) Board
Cutting boards are a valuable, and, at times, under-appreciated kitchen accessory. In this plastic age, we have been overrun with sick, milky-white slabs of questionable origin, claiming to be safe and clean. After a few weeks, you end up with a scarred, savaged scrap, un-saveable, collecting crud in all those crevices. The alternative? A solid, reclaimed hardwood cutting board made from old flooring, hand-rubbed with tung oil to a high, non-toxic sheen. In a pinch, it's solid enough to chock the tires on your inlaw's RV, or knock a kitchen intruder unconscious. It's also cheap (nearly free!), beautiful, and can be continually refinished, lasting for generations.
I put this cutting board together with oak and maple floorboards pulled from old Chicago bungalows. Save what you can from alleys, building sites, and salvage shops, get some good glue, and set aside an afternoon. If you are lacking some of the heavier equipment needed -- thickness planer, pipe clamps, router -- you could laminate it together using the technique found in this table I did a few years ago: https://www.instructables.com/id/Scrap-Table/
You will need these materials:
Reclaimed hardwood (not laminate of any kind!) flooring
Waterproof wood glue
Tung oil
Mineral oil
You will need these tools:
Table saw
Chop saw
Thickness planer
Jointer
Orbital Sander
Router
Clamps
Sandpaper
Rags
Tung oil
Mineral oil
Table saw
Chop saw
Thickness planer
Jointer
Orbital Sander
Router
Clamps
Sandpaper
Rags
STEP 1: Preparation
The first step, key to safety throughout this project, is to thoroughly de-nail the floorboards. One nail can chip teeth off of a table saw blade, ruin a planer cutterhead, or fly up and take an eye out. Go over the boards carefully and remove all nails and staples. If you have a metal detector, use it. Zircon, maker of stud finders, makes a handy pocket-size metal detector that is handy for this sort of thing, as well as finding wires in walls, rebar in slabs, etc.
STEP 2: Tongues and Grooves
Slice off all the tongues and grooves on the boards with a table saw. The best way to do this is set the saw to one width, run all the boards through once, then set to your second width and run all the boards through again, cutting the other side. Now the boards are de-tongued and de-grooved as well as cut to the same exact width. This will help get the cutting board flat and even later.
STEP 3: Surface Preparation
The old finish on the tops of the floorboards will interfere with the glue adhering properly. I ran the boards through a jointer to remove it. That said, you could use a belt sander, a chemical stripper, or a product like Gorilla Glue that is less affected by non-porous surfaces.
To remove the channels routed in the underside of the floorboards, run them through a thickness planer. Yous hould now have a pile of clean stock, with no tongues, no grooves, no channels, and no varnish.
STEP 4: Lamination
Spread waterproof wood glue evenly over the flat surfaces of the boards, then clamp them together with heavy-duty pipe or bar clamps. Alternate the clamps over and under the stock so it doesn't bow or bend. Once the glue has dried a little bit, use a putty knife or razor to scrape up all the glue boogers. If you don't have the heavy-duty clamps required, you could pre-drill, counter-sink, and screw each layer to the next with galvanized screws along with the glue. This is more laborious, but perhaps cheaper. I wouldn't be super-psyched about the long-term stability of that system, but it might work for awhile.
I glued together the broad sides of the stock, leaving the narrow edges exposed, because the narrow edges are essentially quarter-sawn, meaning a stronger edge of the grain is exposed. This will make the surface stand up better to your knife. Secondly, gluing the broad sides puts a lot more surface area in contact with glue and one another, making for a much stronger, more stable board over years of expansion and contraction with changes in weather and humidity.
STEP 5: Surfacing
Run the finished board through a planer, and then sand with 80, 100, and 120 grit sandpaper to get it flat, smooth, and even. Then, put the whole thing on the chop saw and cut into blocks. My original slab was about five feet long and a foot wide, leaving me with four decent-sized cutting boards.
STEP 6: Routing and Finishing
To round over the edges, run the boards through a router table with a generous-sized roundover bit, or use a hand-held router, clamping down the board as you go.
To make the juice channel around the edge, make a simple jig for the router. Depending on how your router is set up, you may be able to simply clamp and adjust a guide that allows you to run straight lines parallel to the edge of the board. If not, simple screw a few pieces of scrap onto the baseplate, as show, to make a simple guide. Put in a channel-shaped bit and set it to about 3/16" deep. Mark a line around the edges of the cutting board, one inch in from each side. As shown in the video, drop in at a corner, run down to the next corner, tip up, rotate to the next side, and continue. Finish it out with hand-sanding.
I finished my board with a base coat of tung oil, to bring out the grain. Tung oil is non-toxic, all-natural product. Look for a brand that uses natural citrus driers and thinners instead of petroleum distillates, so it's food safe. Once that coat has dried, saturate the surface with mineral oil, a clear topcoat you can get in the stomach-remedy aisle of any drugstore. Rub the oil in, buff it out, and let dry for several days before your first use.
When you wash the board, dry immediately with a towel. Don't let it sit in water. After years of use, when the surface is heavily marked up, just sand down and re-oil.
Enjoy!
Enjoy!
20 Comments
GyroGearLoose47 12 years ago
rosebud557 12 years ago
dsalter2 12 years ago
ikoglin 12 years ago
melfinaw 12 years ago
Would that mean that it would be completely saturated with nasty gross bacteria of the hostile kind that no amount of soaking in straight bleach will completely permeate and erase??
I think the concept is awesome, the idea of using used floorboards for my food is definitely not.
wholman 12 years ago
bossfish 12 years ago
AZKAHUNA 12 years ago
dannystaple 12 years ago
tkjtkj 12 years ago
I do suggest tho that you not have long-sleeves while using your great collection of major tools!
Eye-wear, of course, but dont forget the ability of clothing to become entangled with rotating devices!!!
One other thing, as an engineer it would seem to me that this quote is perhaps not so true:
"...If you don't have the heavy-duty clamps required, you could pre-drill, counter-sink, and screw each layer to the next with galvanized screws along with the glue. This is more laborious, but perhaps cheaper. I wouldn't be super-psyched about the long-term stability of that system, but it might work for awhile."
We note that with no screws the board is glued.
but *with* screws it is both glued aND screwed!
I'd also suggest stainless countersunk screws too, .. i never knew a galvanized fastener to staY galvanized for long, certainly not for the generations of family that your design is clearly providing!
Again, excellent 'structable!!
HollyHarken 12 years ago
I would love to own a beautiful cutting board like the one that you made!
ramospk 12 years ago
* Fibers will not dull the knife's edge. Wood is hard cellulose and it will do that, and
* As fibers are cut, they tend to separate from the board, creating splinters.
* When cut on end, wood will be easier to resurface every few months, and will better absorb the mineral oil.
Your design is beautiful, but this minor change will significantly enhance your finished product. Great Job.
vincent7520 12 years ago
I would wear goggles !!¡…
Penolopy Bulnick 12 years ago
CatTrampoline 12 years ago
chubbyvegan 12 years ago
Jobar007 12 years ago
"Research has shown that when bacteria were inoculated on both wooden and polymer boards, bacterial recoveries from wooden boards generally were less than those from plastic boards, regardless of new or used status (Ak et al., 1994a)."
http://fycs.ifas.ufl.edu/foodsafety/HTML/il114.htm
mikeasaurus 12 years ago
