Introduction: DIY Gold Acrylic Abstract Painting
Hey Everyone!
How to make by yourself an abstract painting with gold leaf? First, it’s something that beginners can do for sure.
"Every artist was first an amateur." - Ralph Waldo Emerson
We'll use a cling film as a basic tool, and this is the most creative part. I think you'll be pleased with the results.
Let's start!
Supplies:
- Acrylic paint in your desired colors + White & Gold
- Canvas Frame
- Cling Film
- Gold Leaf Sheets
- Glossy top
- Large paintbrush - for paint and top
- One paintbrush - dry, for gold leaf
Step 1: White Base Layer
Most canvases purchased in the store are already treated with Gesso (the primer). So, we start to work by covering the canvas with white paint.
Take the large paintbrush and soak it in water just at the beginning. Generously apply white acrylic paint from the tube directly onto the canvas, and distribute it evenly over the surface. There is no need to add water or wet the brushes again.
Step 2: Randomness Is Key
Spread the colors randomly across the canvas. Add gold acrylic paint. When you choose darker colors, leave more white background. So you can blend colors better and keep depth in a painting.
Tip: If you are a beginner, I suggest you simply take analogous and monochromatic colors.
It's an easy and winning combination. I uploaded some color schemes for a better understanding of color combinations
Step 3: Blending Colors Using Cling Film
I found that this technique is popular with kids. I use it too... not so messy and pretty good tactile sensations while you blend the colors.
Cover canvas with cling film, not tight. Now, on to the fun part, gentle blend the colors with fingers.
Step 4: Take Off the Cling Film
Step 5: Add Texture to the Painting
Take a square of cling film and a little crumple it. This will be our improvisational brush. Use the gentle and patting movements and go all over the canvas. When you think your 'brush" is dirty and doesn't work well, replace it.
Step 6: Canvas Edges
If you want to hang just a canvas, without a frame, you should add color to the borders.
Step 7: Boosting and Enhancing With Clean Colors
Take another clean piece of cling film, crumple it. Apply a small amount of color that you think your painting needs and make some neat touches on top. I will add a little more white color and more gold.
Step 8: Leave to Dry 24 Hours
To be honest, for me it was sufficient 3 hours to continue working, everything depends on the paint layer. Check when the paint is dry and go to the next step.
If you don't have or don't want to apply the top to your paint, you can add gold leaf to wet acrylic paint and then let it dry. But I don't prefer this solution, because you can stain the gold with other colors and make a mess.
Step 9: Apply Thin Layer of Glossy Top. Use the Same Technic If You Have Brush Marks on a Canvas
Step 10: Gold Leaf
Tear off small pieces of gold (with a dry brush) and transfer them to the picture. Carefully pat it, the gloss top will dry and will work as a glue for gold foil.
Step 11: Let It Dry for a Couple of Hours and That's It!
Step 12: Red-Orange Abstract Art
I hope you enjoyed this tutorial.
If you went crazy with DIY abstract art))) check out my other project: Glowing LED Galaxy Painting
Step 13:
Second Prize in the
Art Skills Challenge
