Introduction: DIY Nothing Power Bank With PD22.5W Quick Charging/Fast Charging
In today's world, where our lives are intertwined with technology, the importance of a reliable power source cannot be overstated. Whether it's for our smartphones, tablets, or any other electronic devices, having a power bank on hand can be a lifesaver. But what if you could not only have a power bank but also create one yourself? Enter the realm of DIY Nothing Power Bank making at home.
But before delving into the exciting world of DIY power banks, let's talk about a remarkable product that has been making waves in the tech world - the 20000mAh Transparent Power Bank with 22.5W Fast Charging capabilities. This sleek and powerful gadget is not only a functional accessory but also a stylish statement piece.
Every electronic device is made professional with a professional PCB board. If you want to make professional & high-quality PCB (Printed Circuit Board), You can visit JLCPCB
JLCPCB is PCB manufacturing company deals in a lot of PCB products including SMT assembly, precision PCB, stencil making and 3D printing. Here 1 to 8-layer PCB 5 pcs are available for $2 only and PCB quality is very good.
now to JLCPCB and get free coupons of worth $60 as new user.
JLCPCB LINK -
Specifications:
- Item Type: Power Bank
- Capacity: Available in 10000mAh, 15000mAh, and 20000mAh variants
- Output:
- Type-C Output: 5V/3A, 9V/2.2A, 12V/1.6A
- USB Output: 4.5V/5A, 5V/3A, 9V/2A, 12V/1.5A
- Input:
- Micro USB Input: 5V/2A, 9V/2A, 12V/1.5A
- Type-C Input: 5V/3A, 9V/2A, 12V/1.5A
- Battery Cell: Utilizes 18650x8 pieces
- Product Size: 145.540.5535mm
- Color: Gray, Yellow, Blue
- Features:
- Supports 22.5W Super Fast Charging
- Supports PD 20W Two-Way Fast Charging
- Equipped with LED Digital Display
- Supports Type C Input and Output
- Dual USB Output for added convenience
Now, let's shift gears and explore the fascinating world of DIY Nothing Power Bank making at home. The beauty of DIY projects lies in their simplicity and the sense of accomplishment they bring. Creating your own power bank not only saves you money but also gives you a deeper understanding of the technology behind it.
Step 1: Collect Materials
DIY Nothing Power Bank: Step-by-Step Guide
Materials Needed:
- 18650 Lithium-ion Battery Cells (8 pieces)
- Power Bank Case
- Micro USB Input Port
- Type-C Input/Output Port
- Dual USB Output Ports
- LED Digital Display Module
- Soldering Iron and Solder
- Insulating Tape
- Screwdriver
Step 2: Follow Instructions
Instructions:
- Prepare the Battery Cells: Gather your 18650 lithium-ion battery cells and ensure they are fully charged. These cells will serve as the powerhouse of your DIY power bank.
- Assemble the Case: Take your power bank case and carefully install the battery cells inside. Make sure to arrange them in a secure and organized manner.
- Install the Ports: Using your soldering iron, attach the Micro USB input port, Type-C input/output port, and dual USB output ports to the power bank case. Be sure to double-check the wiring and connections to avoid any mishaps.
- Integrate the LED Display: Connect the LED digital display module to the power bank case, allowing you to monitor the battery level and charging status with ease.
- Secure the Components: Once all the components are in place, use insulating tape to secure them within the power bank case. This step helps prevent any short circuits or damage to the internal circuitry.
- Test and Troubleshoot: Before sealing the case, test your DIY power bank to ensure everything is functioning correctly. If you encounter any issues, double-check your connections and troubleshoot as needed.
- Seal the Case: Once you're satisfied with the performance of your DIY power bank, seal the case using screws or any provided locking mechanism. Your homemade power bank is now ready for use!
Step 3: Watch the Detailed Video on This YouTube Channel
By following these simple steps, you can create your own DIY power bank that rivals commercially available options in terms of functionality and performance. Whether you're an electronics enthusiast or someone looking to embark on a fun and rewarding project, making your own power bank at home is a fulfilling endeavor.
In conclusion, the combination of innovative products like the 20000mAh Transparent Power Bank with fast charging capabilities and the DIY Nothing Power Bank Making at home opens up a world of possibilities for tech-savvy individuals. Whether you prefer the convenience of a ready-made solution or the satisfaction of creating something with your own hands, the power to stay connected is now firmly in your grasp.
