DIY Photography Backdrop
Intro: DIY Photography Backdrop
STEP 1: Go Get Stuff
You will need:
(x2) 1/2" x 30" pipes
(x2) Pipe clamp assemblies
(x4) 2" x 2" cork pads
(x2) 1" inner diameter copper elbows
(x1) 1" diameter shower curtain rod cut to width of desk
(x1) Roll of photo backdrop paper
(Note that some of the links on this page are affiliate links. This does not change the cost of the item for you. I reinvest whatever proceeds I receive into making new projects. If you would like any suggestions for alternative suppliers, please let me know.)
STEP 2: Pipe Clamps
Put together your two pipe clamps as instructed on their packaging.
STEP 3: Clamp
Place a piece of cork on the top and bottom of the back corner of the desktop as padding. Clamp the pipe clamp to the back corner of the desk (pipe sticking upwards) where the cork is. Repeat on the opposite corner.
STEP 4: Trim (optional)
If your roll of photo paper is longer than the length of your worktable, trim it to length using a chop saw.
STEP 5: Put It All Together
Place an L-bracket onto one end of the shower curtain rod. Pass the other end of the rod through the center of the roll of paper. Attach the other L bracket to the other end of the shower rod.
Place the open ends of the L-brackets onto the ends of each of the pipes. Your photography background setup is now complete. You can disassemble and reassemble this at your leisure.
Did you find this useful, fun, or entertaining?
Follow @madeineuphoria to see my latest projects.
14 Comments
MrErdreich 3 years ago
The Electrobot 8 years ago
Looks great! I am going to build one using PVC pipes :)
crnrstndes 9 years ago
I made one similar but instead of upright pipes I hung my background roll from my drop ceiling with two hooks. Also, I used curtain blackout liner that I got cheap from a fabric store. It works well! Thanks for the post!!
RingoWild 10 years ago
le FabShop 10 years ago
Lindie 11 years ago
Printy 11 years ago
iApple guy 12 years ago
HumptyNose69 12 years ago
Jayefuu 12 years ago
randofo 12 years ago
None of that is probably particularly helpful to you.
We have some photo lights, but they are currently using tungsten bulbs. One of these days I need to figure out a "natural" lighting setup. San Francisco isn't exactly known for sunny days.
conceptualstratagem 12 years ago
splazem 12 years ago
sunshiine 12 years ago
