Introduction: DIY Realistic Knife Halloween Prop
Make a realistic knife prop for your Halloween costume! Quick and easy to make at home. We love Halloween and think this would be a great addition to many different kinds of costumes!
Wood, flexible wire, tape, electrical tape, aluminum foil, red and black paint, cardboard, wooden popsicle sticks, Wire cutters
Step 1: Build the Frame
Take your wire cutters, metal wire, and piece of wood; cut a long piece of your metal wire. Once your wire is cut, wrap the end of the metal around the top of your wood to start the frame. Form a rectangular blade shape around the wood and wrap the end of the metal around itself to secure it.
Step 2: Wrap Your Blade
Take your aluminum foil and progressively wrap it around your blade frame. Your foil should completely cover the wire frame. (DON’T SECURE WITH TAPE YET). Open the top of the blade PARTIALLY and slide in a piece of cardboard, The cardboard should be about the same size as your blade.
Step 3: Strengthen Your Blade
Tape together your wooden popsicle sticks with electrical tape. Then tape it to your inner layer of foil and cardboard to make your blade stronger and less likely to bend.
Step 4: Wrap the Handle
Take your electrical tape and wrap it around the handle until all wood and wire are COMPLETLY covered. This will give your handle a more realistic look and feel. Once fully covered, cut your tape and secure the end to the rest of the handle.
Step 5: Paint the Blade
Take red paint and a paint brush and dab paint on the edge of your blade. then mix in some black with the red to create a darker red. Once both sides are painted use your brush and finger to splatter "blood" on the blade.
Step 6: (optional) Bloody Handle
Take your paint from the previous step and paint it on the hand you plan to hold your knife in. then grab your handle with your painted hand and hold for a few seconds to allow the paint to stick. Pull away your hand to reveal your bloody hand print.
Step 7: Final Product
YAYY YOU'RE DONE AND NOW HAVE A REALISTIC KNIFE PROP!!
Halloween Contest
