Introduction: DIY Simple Hot Gluegun
HERE is a coool ......simple......hot gluegun
I will say you about how it works...?
I used heating element of mosquito vaporizer as a melter for hotglue
I choosed good knight active plus vaporizer
Step 1: Materials Required:
  • mosquito vaporizer heating element
  • pvc pipe
  • small piece of aluminium sheet
  • wires
  • screws
  • flexible aluminium wire (image sown above)
  • cardboard sheet
  • furniture bush
  • etc
Step 2: Setting Up of Heating Element......
  • insert heating element in PVC pipe
  • connect wires
  • tight element with screws to the body
  • turn aluminuim sheet like a con
  • And solder joint
  • Then attach it to heating element
  • take a PVC pipe correct to diameter of hole of heating element
NOW its time to attach switch
  • the best way is to take the vaporizer's switch
  • I took that
  • Attach switch by making hole on body
NEXT is to make a handle,
For that make a hole
Step 3: Making of Handle....
For handle ;
  • insert screw in the handle hole
  • insert a bush (like above)
  • take a card board
  • cut it as a circle in diameter correct to of handle pvc pipe
next step to prepare handle,
  • take a pvc pipe
  • cut it a 20degree slanted position
  • take another cardboard
  • And cover pvc pipe
Step 4: Attaching Handle and Stand
  1. Attach handle to body with screw
  2. take thick wire and bend it like a stand
  3. attach it to body by making hole
  4. Then glue gun look like this.......
Step 5: Finishing of Project....
  1. take a Cardboard piece
  2. cover backside of hot gluegun like pic above
FINISH the project.....
OUR SIMPLE HOT GLUEGUN IS READY...........
thank you.....
this is my first instructable...
