Introduction: DIY: Squeeze Extra Capacity From Old NiCd Batteries
This time I’ll show you how to squeeze some extra capacity from old NiCd batteries.
How I did it - you can check by looking DIY video or you can follow up instructions bellow.
For this project you will need:
Materials:
NiCd Batteries
Tools:
Soldering iron
Screw driver
Knife
ImaxB6AC V2 or other smart charger
Step 1: Preparation
I got 3 18V batteries from old Ryobi cordless power tools. All I known - that those batteries are faulty or not holding charge. I want to check, does it possible to make 2 reasonably good batteries from 3 faulty.
First is need to take them apart and take a look, how everything looks inside. Sometimes it’s clearly visible bad cells.
Looks like someone already was fixing two battery packs before me. I forgot to show batteries voltages, but I remember that one pack was at 12V and two others at 8V.
Step 2: Charging...
The main tool for this process is Imax B6AC V2 charger.
First I charged all batteries fully up. They all nicely took charge and there was no need to make zapping process.
After full charge, I discharge each pack to 12V. Why 12V? This pack is made from 15 cells connected in series and safe limit to discharge each Ni-Cd cell is to 0,8V. 15 x 0,8 = 12V.
I repeat this process few times to eliminate any possible NiCd memory effect. Used cycle discharge/charge function.
Step 3: Discharging and Looking for Bad Cells
After that I take one by one cell and discharge them at 2A of load to 0,8V cut of voltage. Like I said 0,8V per cell is totally acceptable for NiCd cells. All results wrote on each cell.
And now I can see how good or bad are all three batteries.
Here is connected 15 NiCd cells in series. So battery is good, as good is worst cell connected in series. The idea is to take a look and find worst cells and replace them with betters.
Step 4: Testing Results
Here is some testing results. It’s clearly visible, that first and second batteries are better than third.
It’s definitely need to change 2 cells from first pack and three cells from second. Last battery will be a donor.
After some calculation I decided to replace some more cells in first battery, by using second battery pack best cells. Idea is to make one strong battery where cells capacity will be 1200mah or better.
In same method I’ll upgrade battery number two, that all cells will have 1000mah of capacity or more. Last battery pack will be a donor…
Step 5: Separating Good Cells
It’s time to disassemble battery and separate good from bad cells.
Because I’ll use same cell tabs, I’ll disconnected them very carefully. I used a knife and twisted under a tab. By applying tension, spot welds will pop out. It’s quite ‘tricky, so don’t rush and save your self. And of course - don’t short cells.
Step 6: Soldering...
Arranged cells in final battery shape and started soldering.
Step 7: Final Assembly
Time for re-assemble to battery housing.
If everything was done properly it should gives us around 18V.
Step 8: Conclusion
I checked battery capacity before disassembling and now I could compare it with battery capacity after cells regrouping. There was 1200mAh in beginning and after regrouping cells I got 1400mAh of capacity. It’s about 17% increase. Not bad at all.
So, if you’re working on NiCd batteries powered cordless power tools and have some issues with battery capacity - you could squeeze some extra of capacity like I did. Especially, when this fix cost almost nothing, just your time.
