Introduction: DIY Stress Balls
Feeling stressed about school or work? That's not big deal. Now you can make your very own stress ball!! They let you release your stress on them and are a great decoration. Without further ado, let's get started.
Step 1: Gather Your Supplies
For this project you will need a piece of paper, scissors, a marker or sharpie, a plastic bottle, flour, a little bit of tape and three balloons. The piece of paper can be any piece of paper. The plastic bottle can be any type and the size doesn't matter.
Step 2: Fold Paper
Take your paper and fold it into a funnel.
Step 3: Tape
Take your small piece of tape. Place it on the middle of your funnel so it stays together and does not unravel. Then cut off both sides of the funnel so it looks like a shorter funnel.
Step 4: Place in Bottle
Take your plastic bottle and place the funnel in it.
Step 5: Pour Flour
Take little bit of flour and pour it into the plastic bottle using the funnel.
Step 6: Blow Up Balloon
Take out your balloon and blow it up.
Step 7: Place Over Bottle
Take your bottle and place your balloon on top of the bottle.
Step 8: Pour Flour
Turn the bottle upside down so that all the flour will go into the balloon. Take the balloon off of the bottle. Then take out all the air so only the flour is left in the balloon.
Step 9: Cut Off the Tops
Take another balloon. Cut off the tops of both balloons.
Step 10: Close the Hole
Take your glue and put some on the hole in the balloon. This will close the hole.
Step 11: Wrap Around
Take the balloon that you cut off the top. Wrap it around the first balloon with the flour. Put glue on the hole of the second balloon.
Step 12: Wrap Around Again
Take another balloon and cut off the top of it. Wrap that balloon around your first and second ones. Secure it with glue, so it stays in place.
Step 13: Does Your's Look Like This?
So far, this is how your should look. If it doesn't look like this, you might have a little mistake going along. And you might want to go back and try this again.
Step 14: Draw a Smiley Face
Draw a smiley face on your stress ball. You are done!! Not only can you use this to reduce your stress, you can also brag to your friends about making your VERY own stress ball!!! I hope you enjoyed!!!
Homemade Gifts Contest 2016
1 Person Made This Project!
- edhatch0310 made it!
