Introduction: DIY Switch Adapted Bubble Blower
This project is designed to adapt a bubble blower so that it has switch access.
Step 1: Remove Screws
Remove the six screws from the back of the toy. (Note: you will not have to remove any of the screws from the tail)
Step 2: Add Hole
Melt or drill a hole into the very back of the toy to allow enough space for the cables to fit.
Step 3: Cut Cable
Cut the end of the cable. (We will be using the female end for this adaption).
Step 4: Strip Cable
Strip the cable so that there is approx. 4 inches of the red and white cable showing.
Step 5: Strip Cable Again
Strip cable so that the wires from both the red and white cables are showing. (Note: only strip a small portion of the cable)
Step 6: Solder
Add solder to the ends of both the red and white cables.
Step 7: Thread Cable
Thread the cable through the back of the toy. Tie or use a zip tie to prevent the cable from being able to be pulled out.
Step 8: Solder Part 1
Solder one cable to the area shown in the photo.
Step 9: Solder Part 2
Solder the second cable to the area shown in the photo.
Step 10: Reassemble
Reassemble toy.
Step 11: Enjoy
Add switch and enjoy!
