DIY Tennis Balls on Orthopedic Walker
111,635
5
7
Introduction: DIY Tennis Balls on Orthopedic Walker
My grandma recently got a walker and she hates how difficult it is to turn sideways. I've seen other elderly people with tennis balls on their walkers, and assumed that this was the solution. It is :)
Step 1: Materials
You'll need a box cutter, a tennis ball, and something to hold the tennis ball in place (I used my vise). Optional: A hammer and a nail to poke a hole before cutting with the box cutter.
Step 2: Secure the Ball
Secure the tennis ball so that it doesn't move around when you're cutting it.
Step 3: Hammer Time
Hammer the nail into the ball until you hear the air hiss out of the ball.
Step 4: Remove the Nail
Take the nail out of the ball.
Step 5: Cut the Ball
Cut a line starting at the hole. The size of this line will depend on the size of the walker's legs. I cut a line about 2 inches in length.
Step 6: Make an X
Cut another line to make an X shape.
Step 7: X Cut
This is what it should look like.
Step 8: Put the Ball on the Walker's Legs
Push the ball onto the walker's legs, pull back so that the flaps open up, and push it back in so that it is secure.
Step 9: Done
You're done!
Be the First to Share
    • Woodworking Contest
      Woodworking Contest
    • Make It Modular: Student Design Challenge
    • Home and Garden Contest
    7 Comments
    LoriD37
    LoriD37
    1 year ago
    Great job your instructions were easy to understand. The only question I have (don't laugh) bit do you take off the rubber stoppers before you shove the tennis balls on? Keep up the good work
    wlj2015
    wlj2015
    Reply 1 year ago
    No need to remove the stoppers, they fit just fine and are handy to have in case you ever need to remove the tennis balls.
    foxfriend2017
    foxfriend2017
    Tip 4 years ago on Step 2
    Before putting the ball in the vise, wrap a paper towel around it. The vise jaws are probably dirty and will mess up the ball.
    foxfriend2017
    foxfriend2017
    If the nail doesn't work, I would use a drill with a 1/8" bit.
    Markkempe312
    Markkempe312
    4 years ago
    Thanks for the tip! Without this, he upturns the throw rugs and other things in his way. My 91 year old Pop likes the idea! You rock! Great presentation!
    Tcouet
    Tcouet
    6 years ago
    I took a big bag stuffed w tennis balls to my Dads nursing home, the Physical Therapy dept was thrilled!
    The next visit , there was tennis balls on EVERYTHING!! A great way to re use old balls.
