Introduction: DIY Transcutaneous Vagus Nerve Stimulator
Introduction
Transcutaneous Vagus Nerve Stimulation is a relatively new concept based on the more invasive implantable Vagus Nerve Stimulation devices. Originally, the implantable devices would require surgery to put a battery and nerve stimulator in your neck to treat epilepsy or severe depression.
Some suggested applications of Vagus Nerve Stimulation now include:
- Treatment of Anxiety, Depression
- Stimulation of the Migrating Motor Complex in the digestive system to help issues such as Irritable Bowel, Small Intestine Bacteria Overgrowth, Delayed Gastric emptying
- Reducing pain and inflammation in the body (maybe because of MMC improvements)
- dampening Tinnitus
- reduction of atrial fibrillation symptoms
Obviously do your own research on the potential benefits. While the implanted device does has some research favoring its use, the transcutaneous approach has less scientific studies. The main study as of December 2019 is the following, which uses a modified TENS device to stimulate the vagus nerve by attaching a clip to the tragus of the ear, which contains a branch of the vagus nerve.
https://www.aging-us.com/article/102074/text
The afib study is below, and it uses a device to treat tinnitus:
https://www.medpagetoday.com/meetingcoverage/hrs/7...
The device that afib study used is here:
https://www.parasym.co/parasym-device-transcutaneo...
Obviously, that device is a bit pricey, but we can replicate the device using cheaper options.
Disclaimers: transcutaneous vagus nerve stimulation's benefits haven't been validated by the FDA, and there's no promise of a cure of any condition. When using TENS units, please read the instructions and precautions.
Here's what you need:
1) A TENS Unit that will let you set the frequency, pulse width, and intensity. This one, I like because it also has the microcurrent mode (think Alpha-Stim), but you can get anything in their InTENSity line that has the TENS mode.
TENSpros.com InTENSity Micro Combo unit
2) 2 pairs of ear clips
tenspros.com black ear clip electrodes
Note: you can order the ear clips with your TENS device and probably save 50%
3) A Dremel or Rotary device with a cut-off wheel attachment
Example of a Cut off wheel
4) Super Glue - any will do.
Step 1: Disassemble One of Two Ear Clips
You should have 4 one-sided ear clips to start with. We're going to make two double-sided ear clips out of them.
So, set aside the first two. We're just gonna take them apart and keep the side with the electrode on it. The flat side with no electrode can be discarded.
Step 2: Cut Off the Non-Electrode End of One Side of the Clip.
With the two remaining clips, we need to cut off the circular end of the non-electrode side of the clip. This is where the other electrode will go.
With a Dremel or tool of your choice, carefully remove just the circular part of the non-electrode side of two clips.
Step 3: Glue the Electrodes Together
You want to take one of the electrodes in step #1 and glue it to one of the electrodes from Step #2.
Line up the two electrodes as best you can so that they a) face each other and b) touch when closed.
You'll want to stick a pencil or some sort of brace in the middle of the clips to keep them open while the glue is drying. Super Glue works fine. Just make them look like the photos above.
Step 4: Insert the TENS Wires
The InTENsity Micro Combo unit has two wires from each channel. Put one red and one back wire on either side of the ear clip as pictured above.
Step 5: Clip to the Tragus of Your Ear and Turn on the Device
Clip the electrodes to your ears as shown. get them wet by rubbing water on the surfaces to improve conduction
On the TENS unit, set the unit to TENS
- N (Normal, constant current)
- Pulse Width 200 microseconds
- Frequency 30Hz
- Time 20 minutes
Use the up Arrows to turn the device on - you will feel a prickly sensation in your ears. Go as high as you can tolerate, then back down one notch and leave it there for the duration.
