Design and Assemble a Wheelchair Lever Arm: Bottom Stacked Gear
Introduction: Design and Assemble a Wheelchair Lever Arm: Bottom Stacked Gear
Instructions on how to build part of the wheelchair lever arm in solidworks for this project:
https://www.instructables.com/id/Design-and-Assemb...
Step 1: Go Up to Step 4 on This Instructable to Create an Identical Gear Base and Rotate It 180 Degrees
https://www.instructables.com/id/Design-and-Assemble-a-Wheelchair-Lever-Arm-Top-Sta/
Step 2: Sketch a Circle With Diameter 106mm on the Front Face of the Gear and Use "Boss Extrude" to Extrude It 10mm
Step 3: Draw a Circle With Diameter 75mm, Draw a Circle Along That Line With Diameter 5.45mm and Use "Circular Pattern" to Create 3 Equal Holes
Step 4: Use "Hole Wizard" to Create an M5 Counterbore Hole in the Center
Step 5: History Tree
Be the First to Share
    • Lamps Challenge
      Lamps Challenge
    • Rice & Grains Challenge
    • Anything Goes Contest
