Introduction: EV Charger
EV chargers are starting to show up everywhere. We had started an EV project at school and we considered the big commercial chargers but what about a DIY'er? We made this simpler charger. The software interfaced with our card system so any community member could activate the charger with their ID card. Instead of an SAE cord we used a standard NEMA electrical outlet just like at the RV parks or Boat docks.
Step 1: Small Prototype Charger
The first thing to do is build the prototype. Its a small version of the charger than can sit on your desktop. Great for testing code updates too.
I used some surplus Magtek serial readers I had lying around. The came from old Gas Pumps and had a small regulator board attached. I replaced that board with a new one holding a small pic that could watch the serial stream to the display and intercept some control characters. I chose characters the display would ignore but that could be used to control the signal lights and charger port relay.
They have a standard RS232 serial interface. I made a small plate from a scrap of aluminum to hold 4 led's and mounted it to the face of the reader.
3 of the led's are for status of the system and the 4th is to show when the charger port is on. We used Patlite Signal Tower's in the final units. You commonly see these in the supermarket and the checkout line to tell you which register is open.
A green light means the charger is ready and available. A yellow light means the charger is in use. And a red light means there is some fault in the system. Loss of power, network or some other reason the machine is unavailable.
Step 2: Hardware
To get the Linkit to communicate with the display and readers all you need is an RS-232 level shifter. I used the ubiquitous Max232 and mounted it to a proto shield board.
There is plenty of space here to place the pic micro I added to the Magtek reader board. You could even change the code to use Linkit One Digital I/O pins to drive the lights and SSR directly. You would only need a small transistor array chip like a ULN2003. This would eliminate the need for the PIC altogether but I like having the drivers isolated to a separate part of the enclosure. This keeps HV away from the Linkit One.
Step 3: The Larger Proof of Concept Model
This one used the real full sized components arranged on a large piece of particle board and covered by Plexiglas. We had this on display for green week and encouraged people to swipe their cards to see their name appear on the display. Thinking back we should have used the log to give away prizes....
Step 4: Circuitry
It's all pretty straight forward. The Patlite was driven by some darlington transistors. I didnt include detailed schematics since if you are into EV's you should be able to wire a darlington driver blindfolded. As you can see I made my darlington drivers from discrete components but with the new LED Patlite's I found KSP-13's work great.
The unit was powered by a standard open frame power supply most often used in external 5.25 PC Hard Drive cases.
We used a solid state relay to provide a 120V feed to power a large 3 phase contactor.
Even though we know most people used 5-20 and 6-20 outlets on their homebrewed EV's we thought it might be more useful if we also added L14-30 and L21-30 outlets for the bigger projects. I even took a trip to some local stores that supply RV's so see what kinds on power adapter cables they usually stock.
Step 5: Software
We use a proprietary card system vendor that charged us $5000 for the license to interface to their backend. Probably the most expensive part of the whole project. An open alternative could easily be made using just the power of the Linkit One.
I've attached a simple demo sketch to get you started. The SMS capabilities of the Linkit can be used to send text notifications when the time runs out. This would be a nice improvement over our email only notifications.
Step 6: Testing
Here are a few movies of it in action.
Arduino All The Things! Contest
