Introduction: Easy Way to Make Fried Oreos
I am making fried Oreos. It is tasty and super easy to make.
Make sure you have the following ingredients: Pancake Mix, 2 Eggs, Vegetable oil, 1 cup of milk, a bowl, spoon, Pan, Oreos, Plate, or container. Optional: powdered sugar, regular sugar, and a blender
Step 1:
The second step is to pour vegetable oil into a pan and heat it. (I would suggest turning the knob to the number 5, if the oil is too hot it can cause the Oreos to cook very easily, causing them to be burnt!) I am using the same pan and oil from making fried Oreos the other day!
Step 2:
The second step is to Mix the pancake mix, eggs, 2 tbsps. of Vegetable oil, and 2 cups of milk in a bowl with a spoon.
Step 3:
The third step is to check to see if the oil is hot enough. You can do this by dropping a little bit of the mixture into the oil, if the oil starts bubbling around the mixture, it is ready!
Step 4:
The fourth step is to take as many Oreos as you like and dip them into the mixture.
Step 5:
The fifth step is to place the Oreos into the oil. I would recommend using a spatula, so oil won’t splash on your fingers, but you don’t have a spatula, a spoon is fine too!
Step 6:
The sixth step is wait until it turns golden brown on both sides.
Step 7:
the seventh step is to take them out and lay them on a plate or a container
Step 8:
The eighth step is to sprinkle powdered sugar over the Oreos. If you don’t have powdered sugar and only have regular sugar and a blender, to make powdered sugar just blend regular sugar in a blender.
