Ebonizing a Rosewood Guitar Fretboard
105,339
15
6
Introduction: Ebonizing a Rosewood Guitar Fretboard
You can make your rosewood fretboard a nice piano-like black in a few easy steps. It doesn't take much in the way of parts or time, and the result looks fantastic.
I started with a Mighty Mite Neck (CR2910) which has a rosewood finish on the fretboard - however, it really didn't look that great and I was using a black pickguard which made the flaws in the rosewood show even more. The difference in the finish product is night and day - it really looks much nicer, and didn't take much effort at all.
Note: It's important that the NON-FRETBOARD part of the neck has some sort of finish on it. Don't use this method on a raw neck.
Step 1: Preparation
Using a bit of 200 grit sandpaper, lightly sand the fretboard. The key word here is LIGHTLY, you don't want to damage your frets, or make your fretboard uneven. Don't skip this step: this light sanding will make the wood more receptive to the stain.
Once you have that done, wipe down the neck with odorless mineral spirits. I would recommend wearing latex gloves in order to prevent leaving any fingerprints on the surfaces you want to stain.
Step 2: Taping Up the Neck
I used ordinary 2 inch painters tape to mask the areas of the neck that I didn't want to stain. I recommend that you cover the majority of the neck this way; it prevents stray dye marks from appearing on the maple sections. It really pays to be thorough on this step - be patient, and do a good job and it will make the remainder of this project easy.
Step 3: Staining
The wood stain I use is Minwax Ebony 2718. Buy the smallest can available, as you won't really need a lot. I used a foam brush to apply it to the neck. They're disposable and cost under a dollar.
Really lay the stain on there, over the fretboard, the nut and the dots (you can tidy those up later with mineral spirits and a q-tip, and it won't stick to your frets at all). Once you have it on there, leave it alone for at least 10 minutes. The longer it's on there, the darker your finish will be.
(I think anything past 30 minutes is a waste - dark only gets so dark...)
Step 4: Finishing the Job.
Once the stain has been allowed to soak in for the appropriate amount of time, don a pair of latex gloves - unless you like having ebony fingers.
Use a piece of cloth (I used an old t-shirt), rub off all of the remaining dye. When you think you are done, put the neck down and wait for a few minutes, then do it again with a clean piece of cloth. Repeat this step until the cloth comes up clean. If you think the fretboard isn't dark enough, apply more stain and wait another 10 - 30 minutes, then wipe the stuff off.
Once it's "dry," you can now remove the tape. You will notice that some of the stain has bleed under the tape (it's unavoidable), but it's easy to clean that up using mineral spirits and some paper towel
Let the fret dry at least 8 hours (overnight is good). If you need to tidy up the dots or nut, wait until this drying phase is done.
Thats it! A nice deep dark finish on your fretboard!
2 People Made This Project!
  • Big and Small Contest
  • Make It Bridge
    Make It Bridge
  • Game Design: Student Design Challenge
6 Comments
SamL115
SamL115
6 years ago
What if you had a satin neck?
RowanN1
RowanN1
6 years ago
I just tried this method but it all just sat on top of the fretboard and didn't absorb whatsoever. Made a mess trying to get it off. Does this not work on rosewood?
skipernicus
skipernicus
Reply 6 years ago
Did you lightly sand the fretboard? Perhaps there is some kind of sealant that prevents the stain from sinking in.
skipernicus
skipernicus
Reply 13 years ago on Introduction
 Not at all, although your mileage may vary - my inlays were plastic. I tidied them up with a q-tip with a very tiny bit of mineral spirits. I'm not sure how it would effect other materials.
old_bass_masta
old_bass_masta
 good to know, definitely don't use acetone, it would dissolve your inlay.
a guy at guitar center told me that if you use a certain fretboard oil enough, it will ebonize
