Introduction: Entwined Hearts Cast in Aluminum
This project was inspired by Kiteman's Entwined Hearts.
I had just finished building a metal casting furnace and needed to make a valentine's day present for my wife. I found his idea and decided to translate it into cast aluminum. I used a technique called lost foam casting which involves pouring molten metal directly on a pattern made out of foam. The foam vaporizes and the metal fills the void creating the casting. I hadn't tried it before but it's supposed to be fast and easy and involves fire. Who doesn't like that?
Step 1: Cutting the Pattern
First you need a pattern of what you want to cast. You will need two hearts. Mine are about 5" tall and 3/4" thick. Start with a piece of foam insulation. You want the pink or blue stuff that they sell at the hardware store. It's possible to use white beadboard but it's crumbly and won't give as good of a resolution. I cut out my heart patterns on a cnc router (I got the cnc bug from this excellent instructable: www.instructables.com/id/How-to-Make-a-Three-Axis-CNC-Machine-Cheaply-and-/ but ended up using plans from here:www.solsylva.com/ which ended up being a two year diversion) You certainly don't need to use a cnc router to make your pattern. A saw, knife, file etc. will do just fine. I cut out the heart in two pieces and glued them together. Make sure that you add two sprues off the top of the heart. This is where the aluminum will enter and exit the mold. It took about 20 minutes to cut each piece. The ridges in the pattern are because I cut it out at a low resolution. I was too impatient to wait longer for a smoother cut and I thought the they looked interesting. I uploaded the G-code if you want to use my pattern.
Step 2: Preparing to Cast
Now that you have your patterns it's time to fire up the foundry. If you don't have a metal casting set up you can find instructions for building one on this site or there is also an excellent forum/community of backyard metalcasters located here: backyardmetalcasting.com/forums/ I found them very helpful in getting me going with an inexpensive (runs off of waste vegetable oil) home-built foundry. My furnace build is here: backyardmetalcasting.com/forums/viewtopic.php
You can do lost foam casting in a number of ways. I chose to just bury my pattern in loose sand. This is the easiest and most immediate method but it gives you a grainy surface from the sand. I knew I was going to do some finishing to my castings so I didn't mind. I sifted regular play sand into an old soup pot and buried the first heart up to the top of the sprues. Then I took a short can with the top and bottom removed and put it around the entry side. The can acts as a collar to retain the metal and gives you an extra supply to help fill the mold as you are pouring. You also don't have to be quite as precise as you pour.
Step 3: Pouring
I guess it's time to mention that pouring molten metal can be exceedingly dangerous. Please take the time to research it thoroughly and use appropriate safety gear. You do not want to drop a crucible of liquid metal on your foot. I don't know what nasty chemicals are released when you vaporize foam but I would strongly recommend pouring outside and wearing a respirator with organic vapor cartridges in addition to your other safety gear. Once your furnace is heated up and glowing orange melt some aluminum in the crucible. Make sure you have plenty melted, you don't want to run out in the middle of a pour. My hearts took about 1 lb each with the sprues and excess. Have the pot with your mold on the ground near the furnace and all of your tools ready. When you pour the casting fill the metal collar and don't stop pouring until you see a puddle of metal coming out the other side. There will be some smoke and fire but you don't want to hesitate in your pour or the metal can freeze up and the mold won't fill completely. Wait about 5 minutes after the pour to pull the casting out of the sand. You want to be sure it's nice and hard.
Step 4: The Second Pour
After the first casting has cooled enough to handle, cut the sprues off with a hacksaw or sawzall. Cut the second heart and insert the casting so that they are linked like a chain. Glue the foam heart back together. As you bury the foam this time float the first casting in the sand parallel to the bottom so that it doesn't touch the pattern. Then go ahead and cast the second heart the same way you did the first.
Step 5: Finishing
Now it's just a matter of removing the sprues and finishing the surface of the hearts the way you like. I used a saw to cut them off as close to the top of the hearts as I could. Be careful not to cut too much off. Next, I used a grinder to rough shape the tops. I used a file to do the final shaping and to smooth the surface somewhat. I wanted to leave the ridges in the hearts but also have them be smooth enough that they invite you to handle them. Finally, I used 120 grit sandpaper to take out the file marks and 600 grit to get the final finish. This was my first real cnc project and my first casting. I was very pleased with the result and my wife liked her present too.
Like projects? Check out our site where we chronicle our Mighty Projects on our Mini Farm (AKA our backyard).
Thanks!!
First Prize in the
Valentine's Day Contest
62 Comments
9 years ago on Introduction
Awesome post! Wanted to let you know that this inspired me to do my own version!
Hey those came out great! Good work. Thanks for posting a pic.
12 years ago on Introduction
Melting any kind of plastic or foam casues carcinogenic vapors. As a cancer survivor, I feel this is more dangerous then just the molten lead part. How are you protecting your self, family, pets, etc from the dioxicins?
Reply 11 years ago on Introduction
.... um... what molten lead? he's using aluminum.
That was a typo. I know he is using aluminum. why is no one concerned about the vapors from the foam? I don't see anything about ventilation or anything. Interesting.
He has a whole paragraph about wearing a respirator. Read before you comment. Please stop trying to "protect" everyone. Most of us are grownups here and are aware of the hazards.
Wow...happy holidays to you too.
Its been my opinion many folks who create art and craft have no idea about toxicities. People usually are quite happy to know. Go spread your cynicism elsewhere. :-(
Are you always this grouchy Mr Grinch?
Not grouchy at all. Just tired of people acting like we all need to be protected from every little bump, scratch or bad smell we might encounter. The part that upsets me the most is that the original author wrote about using a respirator, working outside in good ventilation and you completely ignored him so you could get your comment in about "molten lead". And then when you were called on it, you said you made a "typo".
I accidently said lead instead of aluminum. Ok--it WAS a typo...like you never have made one before? I already went over that...why beat a dead horse? I still can't find "a paragraph" about using a respirator....maybe its invisible, or my eyes are getting weak.
I think you are trying to start something. Its not neccessary. I have read this entire thread several times...
Why on earth would you be "upset" about this. its ridiculous. there are far greater things in life to bother a person. sheesh. Move on. Move on Brian.
Step 3... Second paragraph
" I don't know what nasty chemicals are released when you vaporize foam but I would strongly recommend pouring outside and wearing a respirator with organic vapor cartridges in addition to your other safety gear."
Happy to help :D
Nobody wants to harm themselves unintentionally. It seems pretty obvious that you don't want to breathe smoke from foam or anything else. I do the casting outside and wear a respirator with organic vapor cartridges.
Not every one is sensible to do this, or even think of it. Just thought it worth mentioning. :-)
people die every year form grilling inside their garage........
People are known to do a lot of stupid things in life....I am doing one right now by replying...;-)
Nice job!
I'm going to scale down your design and cut it on my CNC router out of wax. The I'll use traditional lost wax and make the hearts out of silver. I'll have to add a small sprue between the pieces but that's the only difference.
I can't wait to see pictures! Post some in the comments here when you get some.
What type of CNC do you have?
I've got a CNC Shark Pro and a Roland MDX-40A. I'll use the Roland because it's a lot more precise and I'm just going to be cutting wax.
10 years ago on Step 5
This is a very cool idea. Thanks for sharing!
Would it be possible to scale it down? Or would it just get messy?
I must admit, I was another person to think that they were rather small....
Try it and let me know how they turn out ;)
