Introduction: Face Shield
These are the instructions to assemble the face shields. All that you need is a stapler and scissors
If you have any questions, contact me at 914-844-7905 or jasonslaveneder@gmail.com
Step 1: Peel Film
Peel plastic film from both sides of plastic sheet.
Step 2: Trim
Trim plastic sheet, according to picture above.
Step 3: Prep Foam
Peel adhesive backing from foam.
Make sure that the adhesive backing comes off of the ovals, as you will have to peel those separately.
Note: While pictures may have oval cutouts removed from foam, it is recommended to leave those in place!
Step 4: Stick Foam
Stick foam along the side with the uncut corners. Try to center it as best as possible.
Use picture above as guide.
Step 5: Staple Part 1
Line elastic up with foam, with the loose end going away from the shield. Place the end that will be stapled approx 1/4 inch away from foam strip.
Place 2 horizontal staples, and 1 vertical. Use pictures above as guide.
Step 6: Staple Part 2
Take loose end, and staple the same way as you did for the first end.
This part is a little tricky, so make sure that the elastic looks the same as it does in the pictures above.
