Fading LED With Arduino Analog Output in Tinkercad
30,907
80
6
Introduction: Fading LED With Arduino Analog Output in Tinkercad
About: Learn electronics with Tinkercad Circuits!
Let's learn to adjust an LED's brightness using one of the Arduino's analog outputs. You've probably already learned how to use Arduino's digital i/o pins to send HIGH and LOW signals to an LED, but some of these pins are capable of simulating a signal somewhere in between. These pins are labeled on the Arduino Uno with tildes (~) next to the pin number. We'll connect an LED to one of these special pins and compose a simple program to slowly fade the LED brighter and dimmer.
You can follow along virtually using Tinkercad Circuits.You can even view this lesson from within Tinkercad if you like! Explore the sample circuit or build your own in a new circuit workplane. Click "Start Simulation" to watch the LED fade. You can use the simulator any time to test your circuits. Tinkercad Circuits is a free browser-based program that lets you build and simulate circuits. It's perfect for learning, teaching, and prototyping.
Find this circuit on Tinkercad
If you want to follow along with your physical Arduino Uno (or compatible) board, you'll also need a USB cable and a computer with the free Arduino software (or plugin for the web editor) installed, a breadboard, an LED, resistor (any one from 100-1K ohms will do), and some breadboard wires.
Step 1: Breadboard LED Circuit
The LED is connected in series with a resistor between Arduino pin 9 and ground. Remember that the solderless breadboard rows are connected inside, so you can plug in components and wires to make quick temporary connections.
You'll see the following connections:
  • Breadboard power (+) and ground (-) rails to Arduino 5V and ground (GND), respectively
  • LED cathode (negative, shorter leg) to one leg of a resistor (anywhere from 100-1K ohms is fine)
  • Other resistor leg to ground
  • LED anode (positive, longer leg) to Arduino pin 9
Step 2: Build Brightness Adjustment Code With Blocks
Click Start Simulation to watch the LED fade brighter and dimmer.
Let's go over the simple program we're using to fade the LED, which can be built in code blocks or composed using the Arduino programming language. Click Code Editor to open the code blocks editor.
Start with a control block that counts. Set it to count up by five. Click the dropdown next to "for" and select "rename variable...", then rename it to "brightness". Adjust the "from" and "to" values to 0 and 255, respectively.
Inside the counting loop, add an output block to set one of the special pins, and adjust it to pin 9. Navigate to Variables and drag the brightness block to the output block to set pin 9 to the current value of brightness, which changes over the course of the counting loop.
Add a wait block, and set it to 30 milliseconds. This gives time for the light to shine at each brightness level so you have time to see it before it changes. The duration of this block can be changed to slow down or speed up the fading effect.
The counting loop you created fades the LED from off to all the way on. To fade the LED back off again, we have to create another counting loop. Either drag a new counting loop into the editor, or duplicate this one, and this time change it to count down, start with 255, and go down to zero.
Step 3: Brightness Adjustment Arduino Code Explained
In the code text editor, you can see the Arduino code generated by the code blocks:
  Fade
  This example shows how to fade an LED on pin 9
  using the analogWrite() function.
  The analogWrite() function uses PWM, so if  you
  want to change the pin you're using, be  sure to
  use another PWM capable pin. On most  Arduino,
  the PWM pins are identified with   a "~" sign,
  like ~3, ~5, ~6, ~9, ~10 and ~11.
This first section is a comment, describing what the program does. We'll define and explore PWM in the next steps.
int brightness = 0;
void setup()
  pinMode(9, OUTPUT);
The main body of the program starts out by creating a variable called brightness and sets it equal to zero, then inside the setup() pin 9 is initialized as an output.
void loop()
  for (brightness = 0; brightness <= 255; brightness += 5) {
    analogWrite(9, brightness);
    delay(30); // Wait for 30 millisecond(s)
  for (brightness = 255; brightness >= 0; brightness -= 5) {
The program's loop uses two for loops to count up from 0 to 255 by increments of 5. The analogWrite() function takes two arguments: the Arduino pin number (9 in our case), and a value between 0 (off) and 255 (all the way on).
    To program your physical Arduino Uno, copy the code from the window and paste into an empty Arduino sketch, or click Download Code and open the resulting file using the Arduino software.
    Plug in and upload the sketch to your Arduino Uno board and observe your LED fade on and off.
    Step 4: Fade Circuit Starter
    This circuit is also available as a circuit starter. You can use this circuit starter anytime you want to fade an LED.
    Grab this circuit and code combo any time using the starter available in the components panel (dropdown menu -> Starters -> Arduino).
    Scroll to find the Arduino starter labeled Fade, and double click it to add it to the workplane (you can also click and drag instead).
    Notice how the resistor in this version is "upstream" of the LED, connected between power and the LED instead of the LED and ground. These two circuits both make the same connections, linking up the LED to a signal pin and ground, through a current limiting resistor, which will function on either side of the LED.
    Step 5: Pulse Width Modulation
    The Arduino board is only capable of generating digital signals (HIGH and LOW), but analogWrite(); simulates the appearance of brightnesses between on and off using pulse width modulation (PWM). The LED flashes on and off very quickly, and your eye interprets a dimmer light. The ratio of time the LED spends on vs. off determines how bright or dim the LED appears.
    Pulse width modulation (PWM) creates an oscillating digital signal, alternately driven high and low in a repeating pattern. Each high to low to high period of time is called a cycle.
      You can see an oscillating digital signal on the oscilloscope like the animation above.
      Notice that for each cycle, the width of the HIGH and LOW portions of the graph are changing, hence the term pulse width modulation, or PWM for short.
      Identify the other digital pins on the Arduino Uno capable of PWM, marked with a ~: 3, 5, 6, 9, 10, and 11.
      Step 6: Build a Physical Arduino Circuit (Optional)
      Optionally use your physical Arduino Uno to build the breadboard circuit according to the diagram. The resistor can go in either orientation because resistors aren't polarized, unlike LEDs.
      To program your physical Arduino Uno, you'll need to install the free software (or plugin for the web editor), then open it up.
      Wire up the Arduino Uno circuit by plugging in components and wires to match the connections shown in the Tinkercad diagram. For a more in-depth walk-through on working with your physical Arduino Uno board, check out the free Instructables Arduino class (a similar circuit is described in the second lesson).
      Copy the code from the Tinkercad Circuits code window and paste it into an empty sketch in your Arduino software, or click the download button (downward facing arrow) and open the resulting file using Arduino.
      Plug in your USB cable and select your board and port in the software’s Tools menu.
      Step 7: Next, Try...
      Now that you know how to fade an LED using pulse width modulation (PWM), you're ready to try other Arduino exercises that utilize the analogWrite() function.
      • RGB LEDs use analogWrite() to mix ratios of red, green, and blue LEDs. Simultaneously controlling the brightness of one LED of each of these colors can create almost any color of light.
      • You can use analogWrite() to control the speed of a DC motor.
      • The tone library uses analogWrite() to generate different musical notes with a piezo buzzer.
        Experiment with changing the values in the code's counting loops, and notice the effect on the resulting simulation. Can you make the fading animation go faster or slower?
        Explore analog outputs more by clicking one of the linked exercises above, or continue on with the next lesson about RGB LEDs.
        You can also learn more electronics skills with the free Instructables classes on Arduino, Basic Electronics, LEDs & Lighting, 3D Printing, and more.
        4 People Made This Project!
        • For the Home Contest
        • Game Design: Student Design Challenge
        • Big and Small Contest
        6 Comments
        Rehtori
        Rehtori
        4 years ago
        Clearly this instructable was designed for beginners. Using Scratch kind of visual interface does lower the barrier to get started. I think that's great! Thanks for the author for creating such a professional materials and nice video about it. Also good way to introduce how 123Circuits are integrated into Tinkercad.
        I don't really get the point of being negative on the comments and from an angle "I've been a coder for 40+ yrs and this kind of visual tools suck". Well... I guess if you have been coding for 40+ yrs you are not in the target audience. Enjoy your daily EMACS - I'm 100% sure majority of the newbies / kids find this approach more attractive than the old fashioned way. It does also support nicely learning the basic structures of the programs.
        bekathwia
        bekathwia
        Reply 4 years ago
        Thanks for your comment! Agreed that experienced folks can come across very "get off my lawn" when complaining about newfangled tools that help drop the starting age lower.
        theskett
        theskett
        4 years ago
        As another EE, programming since the early '80s (ZX80 etc.) I similarly find the GUI environments painful and highly non-intuitive :-)
        But clearly Scratch, Block etc. have enough followers to show that there's demand; and if you e.g. check out Scanlime on Youtube, rewriting Robot Odyssey DS, it'll be apparent that some very smart people enjoy GUIs :-)
        Example Scanlime linky: https://www.youtube.com/watch?v=vruq_3C5R94
        bekathwia
        bekathwia
        Reply 4 years ago
        <3 Micah! You nailed it, blocks coding is simpler for kids who are just starting out, but I've offered up both blocks and regular Arduino code explanations in this and the other Tinkercad Circuits lessons to satisfy both preferences and level up the blocks coders when they are ready.
        RaymondR6
        RaymondR6
        4 years ago on Step 7
        As a Electrical Engineer, a computer programmer since January 1972 (using FORTRAN on an IBM 1130 minicomputer), a programming instructor since September 1979, and a present Arduino user, I find this "Instructible" interesting, but coding with "TinkerCAD" awkward instead of just coding in "Processing" and using the simple ICE environment. Coding is simple to type and execute instead of using a mouse and moving blocks around. And I can document my ASCII character code easily to teach others, including sending it by SMS if needed, and verbally.
        bekathwia
        bekathwia
        Reply 4 years ago
        Heya, thanks for offering up your opinion! This tutorial is meant for beginners. Blocks code is not offered up instead of, but rather in addition to, classic Arduino syntax. Young kids may it easier to use color coded blocks rather than lines of text with unforgiving syntax. You can turn off the blocks code in your Tinkercad editor by switching the dropdown to "Text" instead of "Blocks" or "Blocks + Text." Just to clarify, Processing is an entirely different program that happens to have a similar-looking IDE to Arduino (both use Java for their windowing stuff, Processing helps you code in Java and Arduino coding is based on C).
