Flannel Baby Blanket With Satin Binding
539,199
76
22
Introduction: Flannel Baby Blanket With Satin Binding
This Instructable is for an easy basic baby blanket. It has two layers of flannel and a satin binding. It is very baby-friendly in that it can be machine washed and does not need any other special care. The blanket only takes about an hour or so to make.
Step 1: What You Need
-two 1-yard pieces of flannel (or fleece, or minky, or any other cuddly baby-friendly fabric)
-one package satin blanket binding (at least 140 inches long, I use Wrights)
-thread
-a sewing machine and knowledge of how to use it
-something to mark your fabric like tailors chalk
-scissors
-sewing pins
Step 2: Wash Your Fabric
Pre-wash your flannel. This is important because the blanket will be washed a lot and you don't want it to shrink. I usually wash the flannel in warm to hot water and dry it on high heat for maximum pre-shrinkage. Iron your fabric to get any wrinkles out.
Step 3: Measure Your Fabric
Put the two pieces of flannel together with the wrong sides together and mark the largest square you can on the top piece, which should be about 32-34 inches to a side. Make sure that the pieces fully overlap within the square. You can use the selvedge for one of your edges. I generally measure by laying them out on a large cardboard grid that you can get at most fabric stores. Mark each of the edges of the square with tailors chalk or other fabric marker. The mark doesn't have to come out because it will be covered by the binding in the end.
Once you have your marks, pin the pieces together near the marks so that your fabric doesn't slip when you are sewing.
Some people put little yarn ties through both layers at measured intervals or use another quilting technique so that the fabric doesn't slip against itself when it is a blanket. If you want this, then now is the time. In my experience, these blankets are small enough and flannel sticks to itself well enough that you don't really need it for practical reasons.
Step 4: Sew the Fabric Together and Cut
Using a straight stitch, sew your fabric together about 1/2 inch or so in from your marks. I use the edge of my presser-foot as a guide. It doesn't matter what color thread you use in this step. When you are done sewing, remove the pins and cut along your marks.
***If you have a serger, you can surge along the marked line instead of the sewing and cutting in Steps 4 & 5.***
Step 5: Zig-zag or Serge the Raw Edges
Zig-zag or surge the raw edges together to prevent fraying. Again, any color thread will do.
Technically you don't need this step, but I like my blankets to be as sturdy as possible. It also helps stabilize the edges, which makes it easier to apply the binding.
Step 6: Prepare Binding
Blanket binding is a wide strip of satin folded in half. One side of the fold is slightly shorter than the other. Before you use it, you want to iron out the wrinkles. Put your iron on the satin setting and, keeping it folded, iron both sides of the satin.
Then prepare the beginning of the satin. With the folded side away from you and the shorter side up, the beginning end is the one on your left. Take this end, open it up. If the edge isn't even, cut it and gently burn the edges with a flame to keep them from fraying. If you burn too much you will scorch it and it will become all wrinkled. Re-cut and start over if this happens. Then fold the ends to the middle fold so you are left with a point -- like the first steps of making a paper airplane. Close the satin and adjust so that the folds line up on top of each other. Iron.
Step 7: Attach the Binding: Initial and Straight Edge
Here we are going to attach the binding to the blanket so that it has nice neat mitered corners. The trick is to do one side of the blanket at a time so that you don't get bunching in the satin. In the pictures, the slight bumps in the satin are quite exaggerated. It looks nice and smooth in real life.
I will refer to two zig-zag stitches:
-zz1 is a very tight (short stitch-length) zig-zag such that the zigs barely clear each other. You want the width to be ~3/16 inch. On my Brother machine the stitch length is 1.0 and the stitch width is 5.0.
-zz2 has the same width but a longer stitch length (~1/8 inch between zigs), something that looks pleasing to you. On my Brother machine the stitch length is 2.5 and the stitch width is 5.0.
When you sew the satin on to the blanket, stitch near the edge of the satin. Because the shorter side of the satin is up, you will always catch the longer edge, but you want the zig-zag to straddle the satin edge on both the top and the bottom.
Sandwich the flannel in the satin at the prepared end so that the shorter side of the binding is up and the fold of the satin lines up with the blanket edge. Do this so that the satin covers a little more than half of one of the blanket sides. Pin from the beginning of the satin to the corner of the blanket. Starting at the tip of the folded satin, use zz1(backwards then forwards) to secure. Make sure you are catching both the top and the bottom edges of the satin! Then use zz2 to continue stitching to the end of the blanket. If the satin slips some and you have to adjust the pins, don't worry, that is why we are only doing one side of the blanket at a time. Your flannel might have a little fold right at the end near the straight stitch, and that is OK too because it will be covered by the satin and no one will know! When you get to the end, back-stitch about 3 or 4 stitches to secure. Cut thread.
***Tip: if you are getting a lot of slippage of flannel vs satin, after you finish the initial folded bit use both hands to grab the fabric & satin behind and in front of the needle and pull gently to create more tension where the needle is. Make sure you move your hands in the direction of the fabric and feed it through at the same speed as the feed dogs while sewing. I find that when I do this, I don't have to reposition any of my pins and I can go the whole length of the edge without slippage.
Step 8: Attach the Binding: Mitered Corner
This is the most fiddly part of the whole process. When done right, the corner looks very neat and tidy.
Pinch the edge of the blanket and open up the satin. Bend the satin so that the corner of the satin and the corner of the blanket are at the same place, then close the satin so that there are satin folds coming out at 45 degree angles from the corner. Pin.
Now sandwich the rest of the blanket edge between the satin and pin to secure.
Since the satin is slippery, folding the corner can get a little funky. I usually pin through just the back layers of satin once I have them folded nicely and then turn over and and fold and pin through just the front layers of satin . Then I put pins all the way through all of the layers and remove the first ones. As you can see in the 4th picture, I usually have two pins per corner when I am done. The trick is to get the 45 degree folds to line up on top of each other. When you sew, you want the zig-zag to straddle the two edges, so the folds you have to be symmetric to within your stitch width.
Now that you have your folds pinned, use zz1 to secure the folds near the corner (back and forth about 4 stitches each), then switch to zz2 to finish the 45 degree folds, turn the corner, and sew the rest of the blanket side. Err on the side of caution to make sure that you catch both sides of the folded satin. They might not line up exactly and thats OK, as long as both sides are secure, the blanket will be very durable! Again, adjust the pins if needed, just make sure that the middle satin fold lines up with the flannel edge.
Repeat this twice more. For the last corner, pin, but don't sew yet.
Step 9: Finishing
Pin the 4th corner and the first few inches of the side. For the final blanket edge, cut the satin so that it overlaps with the beginning plus 4ish inches. Do the same airplane-wing fold as in Step 6. Iron so that the new folds are on top of each other.
Finish pinning the satin around the blanket edge taking care to make sure that the tip of the satin is even with the edge of the blanket. Sew the corner as in the previous step and use zz2 on most of the rest of this side. Just before the tip of the satin, use zz1 (back and forth) to secure.
Done!!
4 People Made This Project!
  • Big and Small Contest
  • Make It Bridge
    Make It Bridge
  • For the Home Contest
22 Comments
tmwimmer
tmwimmer
3 years ago
Thank you for posting this pattern. I just made this for a friends daughter using minky and flannel. I continually struggle with the mitered corners! It is so frustrating! I have a difficult time pinning the corners and then I guess I remove the pins too early so as not to get them caught in the needle of the machine. How do you keep the pins in? It is such a short distance to sew, remove the pins, and keep it lined up. I miss part of the fold in the back. Also, I used Wright satin blanket binding and did not notice that one edge was shorter than the other. Thankfully I did not have trouble keeping them lined up and did not miss the underside.
line191
line191
Reply 2 years ago
You can see where I usually put my pins in Step 8 picture 4. I move the corner to the sewing machine, position it and put the foot down to prepare for the zz1. Then take out the top pin, do the zz1 stitches, transition to zz2 and start moving down the fold. I take out the second pin just before my needle gets to it. Going slow with the sewing in the corners helps a lot. You can also put in more than 2 pins if that helps you keep the layers from sliding against each other. Its possible that the minky is slipperier than the flannel is against the satin? For me I just care that I catch all of the folded satin, I often have either the front or the back zigzag completely overlapping all of the folded satin, and not straddling against the fold. I prefer that to missing part of the fold completely! And the baby won't mind :-D
sybere
sybere
3 years ago
HI, how did you deal with the split at the mitred corners? did you sew them?
line191
line191
Reply 2 years ago
Hi! I am not sure what you mean by the 'split'. In this method you have a single long strip of folded satin, not 4 separate pieces. You can check step 8 for how I deal with the folding of the satin at each corner.
schmidtco
schmidtco
4 years ago
why does the satin have a short and long side?
LiliUniquely
LiliUniquely
Reply 3 years ago
You sew the binding on short side up. That way you know you aren’t missing the edge of the binding on the underneath, as it’s longer.
JudyD51
JudyD51
4 years ago
I've sewn off and on my whole life, let's just say it's been around 45 years. Anyway, I've never made this type of blanket before but I've admired them. Thank you for these extremely thorough and well written directions! I made one for my granddaughter and I'll be making another for a coworker who is expecting her first baby. Truly, thank you for taking the time to be so thorough in your instructions or I may have never attempted it. Working with satin isn't my favorite thing to do, but you made it painless!
Would I be able to use fleece on one side and flannel on the other. I want to make a lap blanket for my husband. I have a little over two yards of a hard to find fleece pattern. I wanted something a little involved than a tie blanket. I am learning to sew and your clear instructions make me confident.
yeastyvodka
yeastyvodka
8 years ago on Introduction
Thanks for your lovely, clear instructions! I made this blanket for my soon-to-arrive nephew Teddy.
lauribear
lauribear
9 years ago on Introduction
I just have to say this is THE BEST blanket tutorial ever! Thank you so much for sharing. I have followed your instructions to make several of these blankets for family and friends and they come out perfect every time. Great tutorial!
line191
line191
Thanks so much! I am so glad it worked out well for you :) Happy sewing!
jmewald
jmewald
11 years ago on Step 7
Okay, I have made a few fleece blankets, and also a couple of flannel blankets now. I'm a beginning sewer. I get my pre-made satin binding from Walmart. I consistently have trouble with wavy, uneven sewing lines. I lay the blanket flat, put the binding on it, and I pin it down. The front/back appear to be "straight". Then when I start sewing the front, it is a nice even line along the binding, and I flip the blanket over and EVERY time it is wavy and it goes from being right along the edge to as much as 1/2 inch into the binding. I can't see what's going on on the back side while I sew... and it NEVER turns out straight. What am I doing wrong??
lauribear
lauribear
Honestly, use Wright's. It's the only brand that I use now for satin blanket binding. I have tried several other, cheaper brands and exactly the same thing happens to me. It slips around, it's not cut evenly so I can't line it up with the border on my blanket properly, the short side and the long side aren't consistent. It's not you that's making it wavy. It's the cheap satin that's not cut properly.
line191
line191
Reply 11 years ago on Introduction
Hmmm, I am not sure, but satin is a very slippery material to work with. The satin binding you are using has a crease it in right? I have only tried the Wrights Single Fold Satin Blanket Binding, so one thought is that it could be that the brand you are using is slightly different than the one that I have used. One thing that I always do is adjust the pins as I sew, so every 6-12 inches, I check the un-sewn binding and readjust as necessary. Another thing to check, if it is just the back side that is wonky, is that your feed dogs (those moving metal teeth-looking things under your fabric on your sewing machine) are working properly. If they are not in the 'up' position, or if they are not moving, then the bottom fabric may not be moving at the same speed at the top of your fabric and you can get funky slippage. And finally, try to play with distance between the satin crease and the edge of the blanket. It could be that you either have too wide of a gap, or not enough gap. Just make sure that the edge of the flannel is not bent over at all under the satin. Let me know if none of that works and I can thing of other things to try.
beachyme
beachyme
Thank you so much. I'll do better on the "next" one.
beachyme
beachyme
It says "attach the binding to the blanket" and "one side of the blanket at a time".
Then it says "when you sew the satin on to the binding". Isn't the satin THE binding? Does this just mean from the corner of the folded satin binding to the edge of the binding and continue on around? I know, I'm a first time grandmama and new to sewing.
line191
line191
Actually, that's just a typo!, it should be "when you sew the binding on to the blanket" Thanks for catching that, I will fix it now. Also, just to be clear, when I say 'one side of the blanket at a time', I mean one of the four side edges at a time. I realize that 'side' could be taken to mean top or bottom. Let me know if you have any other questions, and I hope this works for you!
michmash
michmash
13 years ago on Step 9
I am having a problem with my zig zag stitch catching the underside satin binding on the edge like the top side.  Any helpful ideas for me??
Michelle
line191
line191
Reply 12 years ago on Introduction
I have a couple of things you might try:
1-Make sure that the shorter side of the binding is facing up. All of the satin binding I have seen has one side that is shorter. Check to make sure that is the case
2-I try to just barely catch the satin edge on the top side. The satin has a little ridge at the end, and I try to put my top zig-zag so that it just catches all of the ridge
3-Try not lining up the fold of the satin completely with the edge of the flannel, leave a little gap. That way the satin is more likely to lie on the fold and retain a shorter and longer side.
4-If all else fails, just put your zig-zag so that you aren't catching the edge at all. You can either try to catch just one of the sides over the edge, or sew a good 1/4 to 1/2 inch in from the edge. It creates a different effect, but looks just as polished.
