Introduction: Foam Dog Stairs
This is Mischa, my 13 year old, cancer-survivor, Maltese. She's in one of her favorite spots, sleeping on the couch, but her joints ache and she can't get up and down her typical doggie stair anymore. They're too steep and narrow for her, so I decided to make her custom steps.
She's very small, so I made the rise on my steps just 4", which is low enough for her to walk up without jumping. I made the run (depth) a full 12" which is enough for her to get all the way up one step before she has to climb the next one, even when she's facing directly up the stairs. Finally, I'm making the stairs 24" wide which gives her enough room to turn sideways and lay down. Since I'm using foam sheets as my material, the same stuff the couch cushions are made of, each step is basically a doggie bed. And yes, I've caught her sleeping on the final stairs.
Step 1: The Material
This is a dense upholstery foam sheet, 4" thick by 24" wide by 72" long. I found them on Amazon for $43 each. I need a total rise of 12", or three steps, so I'll be cutting out:
- Top step: 12" x 24"
- Middle step: 24" x 24"
- Bottom step: 36" x 24"
That divides a single sheet nicely into three parts, which I can just stack to make my stairs.
Step 2: The Tools... Well, Tool.
Yes, that's just an electric carving knife. I'd hesitated for a long time before starting this project because I wasn't sure how I was going to cut the foam cleanly; I thought I'd need to compress it with a straight-edge and use a very sharp utility knife. I didn't want to purchase a specialized foam-cutting tool, since I only needed to make three straight cuts.
I found a DIY foam-cutting router-like device demonstrated on YouTube, and it was just a table with one of these carving knives mounted underneath with the blade poking up through a hole. So I decided to try it freehand, and it cuts really well! Nice clean cuts, no burning, no bits of foam everywhere, and it's easy to get a fairly straight line.
Step 3: The Layout
I just measured out 12", 24", and 36" from one edge, and drew lines using a sharpie. Can't get simpler than that.
Step 4: Cut and Stacked
You can see that my cuts are about as straight as my layout lines were. Let's just say they've got that handmade "character". I planned to cover them, so I wasn't too concerned.
I had also planned to glue them together, using some spray adhesive. I decided not to; spraying the stuff inside my apartment, without great ventilation, seemed like a bad idea. It turns out that the foam sticks to itself really well too, so mostly the steps don't move around once stacked. Your results with a bigger dog may vary, though.
Step 5: Covered (loosely) and In-place
I bought some fabric to use to make a cover, but that'll be a future project. For now I've just draped the fabric over the steps and tucked it in. This has been working well enough, but a fitted and sewn cover will definitely be better.
I've also shown the old stairs, for comparison. The difference is huge, and those little steps cost as much on sale as as the foam sheet. Their regular price is $60.
Step 6: Happy Dog
Finally, here's Mischa trying out her new stairs. She's much happier, now that she can get to and from her favorite spot on the couch!
9 Comments
2 years ago
One other advantage to foam steps, is that when you trip over them or stub your toe, it doesn't hurt your foot!
2 years ago
Thank you for making this post. I ran across it by accident, but will mark it up as one of my most useful finds. I have been searching for stairs that were wide and short with little luck, besides an expensive custom job. I have five dachshunds, so you can imagine my need for stairs in just about every room of my house. Thankfully I only have one with back issues, so far that is, but this will save my back and his feelings. He gets very sad when everyone else is on the bed and he can't make it up. Thank you!
Reply 2 years ago
You're welcome! Mischa is 16.5 yo now, and still using her stairs despite her back and leg problems getting a lot worse. I've made a set that's six steps high and runs down one side of the bed so she can climb in and out of bed herself. I never made fabric covers; over time I found myself reconfiguring and trimming the steps, so leaving them uncovered has worked better. If I did cover them, i'd do them individually, and i'd try to figure out a design that could be made narrower if needed.
4 years ago on Introduction
I am doing the same thing for my 15 year old a jack Russell..I already have the stairs done(finishing the top ..last one) but was looking for what would make a good cover
Reply 4 years ago
To be honest, I bought a bunch of fabric and a roll of zippers and borrowed a sewing machine, but I never made any covers. I did make three sets of steps though, and it's actually been convenient to be able to rearrange them in different configurations, and cut them down narrower when needed. I wouldn't have been able to do that with a single cover. I'd recommend a simple cushion-style cover for each step so you have some flexibility. The only drawback would be keeping them in place; the foam sticks to itself really well, so the uncovered steps don't move around that much. Covers might make them slip around more.
Good luck!
PS: Here's the fabric I bought. It's a microsuede with Scotchgard protection; basically pre-treated couch cushion material. It seems like it'll work really well, if I ever get around to using it. It's supposed to be dry-cleaned, but I've actually run my couch cushion covers through the laundry and they seemed to come out ok. (It might be bad for the Scotchgard, I guess.)
https://www.amazon.com/gp/product/B00OZ8TMDE/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
4 years ago
This is amazing. You work is brilliant.
Reply 4 years ago
Thank you! I really appreciate that. Watch for my followup project, where I figure out how to sew a cover. :)
4 years ago
My old cat could have really used something like this.
Reply 4 years ago
It seems like an obvious product, but I just couldn't find anything commercial like this.
