Introduction: Food Gameboy
This is a game that has both rewards and punishments.
Step 1: Food Gameboy
Materials used:
Arduino Leonardo
Breadboard
Servo motor 2
LED 5
Button 5
Resistor 10
Male-to-male Jumper Wires 15
Male-to-female Jumper Wires 10
Hot Glue Gun
Cardboard
Plastic sheets
Wrapping paper (for decoration)
Utility Knife
Scissors
Tape (to temporarily secure the components)
Double sided tape
Computer
Step 2: Put Everything on the Board
White LED --D3
Red LED--D4
Blue LED--D5
Green LED--D6
Yellow LED--D7
Motor---D2
Motor---D8
Button1--D9
Button2--D10
Button3--D11
Button4--D12
Button5--D13
Step 3: How to Build the Exterior
You need to have a cardboard and plastic board
Cut the cardboard according to these measurements:
Length 7.5 width 22 cm (x1)
Length10 width 22 cm (x1) (Remember to cut out holes for the buttons on this rectangle)
Length 5 width 22 cm (x1)
Length 5 width13.5 cm (x2)
Length 6 width 15.5 cm (x2)
Length 6 width 22 cm (x1)
Step 4: Body Shape
Put the rectangles together as shown in the picture. There are no rectangles behind. Every component is on the picture.
Use male-to-female jumper wires to connect the LED to the breadboard. Use hot glue gun to secure the wires to the LED.
Insert the buttons into the holes. If the holes are too big, use hot glue gun to secure the buttons.
Step 5: Making a Candy Place
Roll out 2 plastic cylinder with a diameter of 4 cm and a height of 25 cm
Cut out 4 trapezoid with an upper bottom of 3 cm, a lower bottom of 11 cm, and a hypotenuse 6.5 cm
Cut out these rectangles:
Length 4.5 width 10.5 cm (x4)
Length 10 width 11 cm (x4)
Length 5.5 width 6.5 cm (x4)
Step 6: Candy Place
Put together the components as shown in the picture.
Tape the motor on the side of the cylinder. You HAVE TO USE HOT GLUE GUN TO SECURE EVERYTHING. Tape a piece of plastic sheet on the motor to act as a gate and keep the cards on top. The largest rectangle is just to stabilize the structure, so you can make it whatever size you want.
Step 7: Arduino Code
Step 8: Cards
Write down the rewards and punishments on small pieces of cardboard. The size of the cards depends on the size of the hole which the cards would drop through.
Step 9: FINISH & How to Play
This has a password.
The password is 134, meaning you should press the first, the third, and fourth button from the right at the same time. When you enter the password, the right motor will rotate and the reward card will fall. You can then exchange the reward cards for actual rewards.
The punishment:
If you didn’t press the correct password, the left motor will rotate and the punishment card will fall. You must accept the punishment.
Be sure to press three buttons at the same time to start the motor.
It won't move with just one button!
There will be nine types of punishment.
You can use this to play password guessing games at parties or gatherings.
You can create your own clues for the password.
