Introduction: Frankenstein Bolts - for Nearly Free!
I already had a costume this year, but I was asked to make some bolts for a Frankenstein costume. Seeing as I'm obsessed with Halloween costumes, I figured I'd put some time into it.
It only takes about 1 hour, depending on how hard you work on it. It should be ready to wear in about 2 hours after the paint dries.
Disclaimer: it's all your fault. All of it.
Step 1: First, Drink Juice.
I realize this is counter-intuitive, but this is where the bolts will come from.
I had some bottles sitting in the recycling bin, and thought they looked like excellent bolts, since they have the screw threads on them already.
Hobby knife
Hot glue
Super glue (i.e. Cyanoacrylate)
Needlenose pliers
Plastic nippers. some pliers have nippers, this is probably Ok.
you will also need:
Bottles- preferably from juice or non-carbonated bottles. The carbonated bottles have channels cut for releasing pressure and don't look quite right.
- I used square playroom foam (that I'd bought for another project) Less than $1.00
- How else are you going to make it look like metal? I had this laying around from my other instructables. Maybe 5.00 a can...
- I think everyone has some of this laying around. The thicker stuff is the best.
Tools
ScissorsHobby knife
Hot glue
Needlenose pliers
Step 2: Cut Cut Cut Cut Cut, I'm a Kniiiiiiiiiife, Cut Cut Cut
Sorry, obligatory space ghost comment.
Rinse and dry the bottles - no need to get juice residue on all your tools and hands.
Cut the plastic bottle's top off. Leave some of the thicker plastic on it still, we need that.
If you hold it so the mouth is facing downward, you can start to see the shape of the bolt.
Cut two of them. Frankenstein did have 2 bolts/electrodes on his neck, so far as I remember.
Cut the center of the cap, cutting the threads and sidewall of the cap. We want just the center.
Again, do this 2x.
Random fact;
the bottle is formed by blow-molding, the plastic tube before blow-molding is called a parison. The parison is placed in the mold, and hot air is blown into it, until it fits the shape of the mold.Cut two of them. Frankenstein did have 2 bolts/electrodes on his neck, so far as I remember.
Now, for the cap
The cap will act as the cushion as well as retainer for the wire to hold the whole contraption to your neck. In case you can't tell from the pictures, we're going to make the equivalent of a set of over-the-head headphones that will pinch the sides of your neck.Cut the center of the cap, cutting the threads and sidewall of the cap. We want just the center.
Again, do this 2x.
Step 3: Bolts Have Hexes on Them!
We need something that can be easily cut into hexes for the top of the bolt.
I had foam laying around, so I used that. You can feel free to use whatever you want. However, use common sense though since this end of the bolt is going to be farthest away from the attach point - weight is key!
They don't really care about perfect hexes, and neither did we. If you're anal, remember that it has 6 sides, 120 degrees between the sides, and the sides are all the same length. If you really don't care like I did, a piece of paper and eyeballing will work.
I should say a "straight enough" line.
Using my hobby knife, I cut a groove/channel in this to let the plastic fit into the foam and sit flush. This gave me surface area to hot glue to.
Draw a hex
Do this anyway you like, I was lazy so I freehanded this, and it was going to be shown to kindergarteners.They don't really care about perfect hexes, and neither did we. If you're anal, remember that it has 6 sides, 120 degrees between the sides, and the sides are all the same length. If you really don't care like I did, a piece of paper and eyeballing will work.
Cut the hex
I marked the cut points on the foam by poking holes with my pencil. I then used the scissors to cut a straight line between them.I should say a "straight enough" line.
Mount the hex
Here's where I used the left over bit that we didn't cut all the way down - press this against the foam and twist. This lets us figure out where the bolt will touch the foam.Using my hobby knife, I cut a groove/channel in this to let the plastic fit into the foam and sit flush. This gave me surface area to hot glue to.
Step 4: Paint!
Pretty simple.
Paint it!
Spray it!
Color it!
Paint it!
Spray it!
Color it!
Step 5: Bend the Wire
Using a coat hanger wire, I bent the wire around my neck to find the ideal location for the plugs. I had a coat hanger with thicker than usual gauge wire and it worked extremely well.
For some reason the curve of wire ended up smaller than I'd imagined my neck to be. If yours feels small, it's probably not.
Make sure that everything is how you want it before you start the next step!! There's no going back after this!
Well, you could just make a new set. But you'd have to go buy more juice!
After that, put it on and enjoy! you're finished!
You can figure out the make up yourself.
Cut the caps
Using the nippers, cut a small triangle on the cap, and a small triangle on the bolt. This will allow the wire to pass thru and loop around your neck.Glue the whole thing together
Glue the cap to the hanger, and use super glue on the cap to the bolt.After that, put it on and enjoy! you're finished!
Step 6: Lessons Learned Discussion (optional)
I'd actually tried gluing these directly to my skin. I tested it by gluing a bottle cap to my skin for 4 hours.
I don't recommend gluing them. The glue might have toxins in them.
One other reason - it doesn't work!
The weight is too great to be held by glue, even spirit gum. Thus, I settled for the wire.
Thanks for your attention.
What's my point?
Please, if you experiment and something doesn't work, please write about it! I'd like to see instructables with ideas that have failed! What did you do to work around it?Thanks for your attention.
