Introduction: UCSB MAT Computational Fabrication - Nesting Cups
This is a documentation of my process for Dr. Jennifer Jacobs' Computational Fabrication course at UCSB. It shows how I went from calibration and experimentation to nested cups.
Step 1: Calibration Cube
My first step was to level my print bed and print a calibration cube. I lucked out and my first print seemed to be quite good and within tolerance. Using calipers, I was able to measure exactly.
- x = 19.81
- y = 19.82
- z = 19.97
Step 2: Experimentation
After getting our code for affine transforms to work, I was enamored with the shape of a cube intersecting another transformed cube, so I performed a union of two shapes and made a tiny print.
Step 3: Nesting Bowls
Using our offset transform code, I was able to design a very simple and clean bowl.
I'm still getting accustomed to designing at proper scale in Rhino, so I ended up using Ultimaker Cura to scale it to 5 centimeters in diameter.
The print took 2 hours and 45 minutes. I experimented with various settings to get the print time down, but in the end nothing I did changed the time significantly enough to merit deviating from settings I know work well.
Step 4: Nesting With Size Variation and Aligning Bottoms
The next step of the process involved creating 3 nested bowls that varied in size and allowed the bowls to be placed inside of one another.
There were a few "nuts and bolts" things I was struggling with in Rhino, so I decided to keep things very simple to ensure I understood what i was doing. Here are some of the things I had trouble with:
- How to ensure geometry was aligned with a single surface. In my case I needed the bottoms of my cups to be directly at the x axis. The bottom of my cups were concave, so this was a bit of a challenge.
- How to work with scale properly from the start so that I understood what size I was actually making things.
- How to move things in a precise way and target specific points in geometry to be the center of my transform.
All of these issues were solved by working through a tutorial on LinkedIn Learning which was very in depth. I feel much more comfortable with Rhino now.
Step 5: Completed Nesting Bowls
The nesting bowls completed.
The biggest learning stumble for me in this project was learning to align objects with a plane in Rhino, but once I got that down it was easy and prepping my objects for the build platform was easy.
