Introduction: Garage Door Opener With Position - ESP2866
Update 19th Jan 2021: There is an LoRa Controlled Garage Door version of this project.
Introduction
This Internet Garage Door opener uses an OLIMEX ESP8266 EVB module and an accelerometer to measure the position of the tilt-a-door and limit switches. The control over WiFi or Internet is via pfodApp. 128bit security is used to protect against un-authorized operation. Connection to the local WiFi network and configuration of the device's IP and portNo are via web page. No Android coding is required, the pfodApp takes care of all of that.
Features:
- Simple construction – One main board and small daughter board, one resistor and 6 wires
- Simple to configure – Push button configuration of WiFi Network SSID and Password and device IP and PortNo
- Simple to use – pfodApp provides the Android interface. No Android coding required
- Secure – Uses 128bit security
Step 1: Construction
Construction consists of two parts:- the control module and the installation of limit switches and door mounting and wiring.
Construction of the Control Module
The control model use an OLIMEX ESP8266 EVB module which has a built in relay. The relay is wired in parallel with the existing garage door pushbutton. When the code pulses the relay, the garage door operates. To detect the position of the door there are limit switches at each end of the door travel as well as an ADXL335 breakout board from SparkFun. The limit switches act as a backup for the position reading from the ADXL335.
Only one of the outputs from the ADXL335 is used. A 33k resistor to ground on that output reduces the signal level to less the 1.0V as required by the ESP8266 TOUT ADC input. Due to the variation in the ADXL335 specs, you may need to reduce this resistor to 27K.
The schematic is here as a pdf.
The photos show the wiring of the control module.
The ADXL335 break out board mounted on the OLIMEX relay with heavy duty double sided tape. The 33K resistor to ground is mounted directly on the break out board. The configuration push button is connected between GPIO2 and GPIO0 (See Using ESP8266 GPIO0/GPIO2/GPIO15 pins)
Cat 5 cable (8 way) is used to connect the control module to the 5V USB supply, 2 limit switches and garage door push button.
The wires used in this project where:-
- Orange/White for 5V (+5V orange)
- Green/White for Close Limit Switch, normally open (GPIO12, GND)
- Blue/White for Open Limit Switch, normally open (GPIO13, GND)
- Brown/White for Relay output for Push Button contact (in parallel, normally open)
Sold core Cat 5 cable was used for the main wiring and stranded Cat 5 cable was use for the flexible connection to the control module.
Step 2: Installation
The control module was installed on one of the rotating arms of the tilt-a-door, with stranded Cat 5 cable back to a terminal strip.
Solid core Cat 5 cable runs from this terminal strip back to the terminal strip mounted on the tilt-a-door control unit.
The limit switches are mounted on each end of the tilt-a-door's central rod.
Step 3: Calibration and Final Coding
Once the control module is mounted, it needs to be calibrated to the movement of the arm. The calibration sketch is here, GarageDoorAngle.ino.
To load the sketch you will need a separate 5V supply for the OLIMEX module. See this page for details on programming the OLIMEX.
Modify the sketch to put in your network's ssid and password. The IP address is set as 10.1.1.110. You can change it in the setup() if you need to. The portNo is 4989
Load the sketch into the OLIMEX module. Secure the lid on the box attached to the door. The power it up and connect using pfodApp. There will be just one button available, “Plot the Angle”. Pressing this button will show a plot of the ADXL355 reading at 1 sec intervals. Open and close the door to get the range of readings.
The reading are also saved to a file on your mobile.
In this case the filtered reading for OPENED was 1000 and the reading for CLOSED was 673. If they go the other way, mount the OLIMEX board the other way up. If the reading does not change much, use a different output from the ADXL355 board to get a larger range of change.
In addition to the analog filter on the output of the ADXL355, a digital filter was added in the code. This filter averages the last 32 readings to filter out noise and mechanical vibrations. The sampling interval is 10mS so this filter averages over the last 0.32Sec. Note: this filter is not the common exponential filtering. Exponential filtering uses less storage, just one floating point location, but requires a time consuming multiplication. But more importantly, a large spike in the input takes a long time to die away in an exponential filter. On the other hand the true averaging used here completely discards any spike from the calculation after 0.32 seconds. This was considered an essential feature because of the vibration observed at the end points of the door's travel.
Final Coding
In this setup the filtered reading for OPENED was 1000 and the reading for CLOSED was 673. So the values in the code were set at 995 to 678 (within 1.5% of open and closed) for 0% to 100%
When the CLOSED limit is operated the sketch will display the “OPEN” button. When the OPENED limit switch is operated the sketch will display the “CLOSE” button. The limit switches are a positive indication that the door has reached that position. Previous testing has shown that if the limit switches move they tend to move away from the door slider and so do not operate at all. If a limit switch wire drops off, the most likely fault, then again the limit switch will not be detected as operated. In either case the garage door position slider will just indicate the position of the door, 0% or 100%, and the pfodApp will just display the Start/Stop button, which will indicate this fault.
The pfodApp will display a navigation screen with a slider below it. The Navigation buttons will be,
- UpArrow for Open – Only shown when the CLOSED limit switch is operated and the OPENED limit is NOT operated.
- DownArrow for Close – Only shown when the OPENED limit switch is operated and the CLOSED limit is NOT operated.
- Home for STOP/START – Shown when neither the up or down arrow is shown OR if both limit switches are operated.
See the screen shots at the beginning of this instructable.
Step 4: 128bit Security and Configuration Password
As well as setting the end points for the position sensor, you need to generate your own 128bit configuration password. This password secures the temporary WiFi connection used to set your local network's real password. This same password is also used by pfodApp to protect against un-authorized access to the control of your garage door. You could set different passwords for these two functions but it is convenient to have just one QR code and use the same password for both.
To generate a random password and the associated QR code, a SecretKeyGenerator java program is available here which generates random 128bit keys and writes out QR.png files. Another alternative is to use QR Droid Private (from Google Play) to create a QR Code for your own chosen password.
Here is the OpenOffice template that was used to print out the QR code and other connection details for this project. Update it with your own QR code and password.
In either case you need to update the #define near the top of the sketch with your own password.
// =============== start of pfodWifiWebConfig settings ============== // update this define with the password from your QR code // http://www.forward.com.au/pfod/secureChallengeResponse/keyGenerator/index.html #define pfodWifiWebConfigPASSWORD "b0Ux9akSiwKkwCtcnjTnpWp" // You can also set your own configuration Access Point name, if you wish.
The completed sketch is GarageDoorWithPosition.ino. See this page for details on programming the OLIMEX. To compile the GarageDoorWithPosition sketch you will need to install three (3) libraries. You need to install pfodParser.zip and pfodESP8266BufferedClient.zip from here. You also need to install the DeboucedSwitch.zip library from here.
You can then attach the QR code, containing this password, to you module or in some other suitable place, so you can re-configure the module when necessary and scan the password into pfodApp in-order to make a connection.
Step 5: Connecting to the Local WiFi Network
Once you have completed the final coding and installed the module, you can use the push button to enable configuration mode. Hold the push button down while applying power to the module. The module will set up its own WiFi access point, pfodWifiWebConfig, which will be visible on your mobile phone. Scan the QR code to get the password for this access point and paste it into you WiFi setup in order to connect your mobile to the module's configuration web server.
Then in your mobile's web browser, enter 10.1.1.1, to open the configuration web page.
The WiFi Shield automatically fills in the Network SSID with the local network with the best signal strength. This will usually be the one you want. If not just overwrite that entry. You must enter a Network SSID and password and portNo. The IP address field is optional. If you leave it blank, the WiFi Shield will use DHCP to get its IP address on your local network. It is often easier to specify a specific IP address so you can easily connect to the module.
Step 6: Operating the Garage Door
Once you have connected the module to your network, you can set up a connection in pfodApp as described in pfodAppForAndroidGettingStarted.pdf. In the connection screen, click the Scan QR button and scan the code above to fill in the 128bit security password.
On connecting you will see a screen like one those at the start of this instructable.
Press the OPEN button to open the door. You can stop the door mid way using the Stop/Start button which is displayed as soon as the door moves off the limit switch.
That's all there is to it.
6 Comments
Tip 6 weeks ago
4 years ago
Updated code to Rev 4 to work with ESP8266.COM IDE plug-in V2.2 (Needs pfodESP8266BufferedClient library)
5 years ago
Updated code to Rev 3 auto reconnects to WiFi network, ignores user input for Position slider. (Needs V2.0.2 of pfodesp8266wifi.zip library)
5 years ago
Updated code to Rev 2 to prevent double clicking of Open/Close buttons
5 years ago
Updated with revised software sketch and libraries - 26th Nov 2015
5 years ago on Introduction
>From: twisener
>Date: Aug 28, 2015. 10:45 AM
>Subject: https://www.instructables.com/id/Garage-Door-Opener-with->Position-ESP2866/
>Looks fun! Could you post the input / output of your board so I can duplicate it with a generic ESP8266?
The GPIO numbers are shown on the diagram. Which generic ESP8266 are you using. I used the 'generic ESP' setting to program the baord.
