Gee-haw Whammy Diddle
Intro: Gee-haw Whammy Diddle
This is my third instructable in my toys category ("Floating Pingpong Toy", "Solar Plane").
"Gee-Haw whammy diddle" is a toy that not only has this great playful name, it also is magical by how it works!
It's simplicity and the physics behind it, made me curious to the point i had to build one,
This is a quick instructable anyone can finish in 30 minutes!!!
STEP 1: Sticks
For this toy we need two sticks:
Main one with notches and a plane one,
I choose a stick with 1.5cm in diameter and 20cm long and for the second i cut a stick of 15cm long.
STEP 2: Notches
The notches should be located at the top of the stick, about 10cm, where you should leave enough space to hold the stick, bottom line: 8cm (handle) , 10cm (notches), 2cm (blank).
With a hand saw, cut notches in 30-45 degrees as shown in the picture.
STEP 3: Propeller
I used a scrap of thin wood 5cm long, marked the middle and drilled a hole.
IMPORTANT: the hole should be twice larger than the nail you are using(in diameter).
STEP 4: Play!
Hold the "handle" firmly to direct the vibration to the propeller and with a second stick rub the notches.
Enjoy!
Challenge:
Try controlling the direction it spins...
P.S
If you are looking for the physical explanation of how it works, you can visit here
9 Comments
Penolopy Bulnick 4 years ago
GregnCindyP 4 years ago
jmdushi 4 years ago
YaronShemesh 4 years ago
The "magic" behind it made me make one.
zakbobdop 4 years ago
jameslstephens36301 4 years ago
Will try...
pgs070947 4 years ago
