Introduction: Ghetto DIY Pillow Speaker
A $2 DIY replacement of an $8 radio shack toy. Listen to music in bed without uncomfortable headphones! Free mints too!
Needed parts:
Sour Altoid can
Crap headphones
Chunk of soft foam
Old internal computer speaker
Step 1: Ready the Cheesy Earbuds
1. Grab a pair of cheap 97 cent walmart earbuds (or dollar store ones with free scan radio!)
2. Snip the actual speakers off from the cable. Save them for later use as ninja throwing weapons.
3. Poke a small hole through the side of the altoids tin.
4. Stick the wire in through the hole and tie a knot in it 2 inches from the cut end so it doesnt come out.
UPDATE: 5.Put some duct-tape or electrical tape around the wire that will be going through the hole and around some of the knot so the tin won't cut into it.
Step 2: Foam Chopping
1. Find a one inch thick piece of soft foam. ( I used a chunk of couch foam)
2. Cut a circle that will fit in the tin. Hollow out the middle for the back of the speaker.
3. Cut a smaller peice to go on top of the speaker. Make it very thin.
Step 3: Connect Speaker
1. Find an old speaker from the front of an old computer, Or just use any speaker that will fit nicely.
2. Desolder the red and black wires from it.
3. Solder the headphones wire to the speaker. Both colored wires go to the + side and both copper wires go to the - side.
4. Put the bottom foam in the tin and seat the speaker in it.
5. Pull the extra wire out through the hole so the knot is against it.
Yay! The bottom is done.
Step 4: Make a Grill
1. Find a decently strong cutting device (Steak knife).
2. Make three paralell slits along the lid of the tin. I made them along the logo to make them less noticable.
3. Flatten the lid a bit so the bent metal won't poke the speaker or make scratchy noises.
Step 5: Put It Together
1. Place the smaller foam disk in the middle of the lid so it covers the slits.
2. Put the lid on the tin. Make sure it isn't squishing the speaker too badly. If it is, trim the foam down so its thiner.
3. Give the cable a few small tugs to make sure the knot holds. If it doesn't, take it apart and tie the knot better, or put a glob of hot glue over the inside of the hole.
Step 6: Enjoy!
Plug the speaker into an audio source, stick it under your pillow, and enjoy the comfortable fruits of your labor.
Note: My thinkpad is running DSL 1.4 because the HD is shot. Donations gladly accepted. :)
106 Comments
10 years ago on Introduction
I did it! First time I've soldered, but I had a gun in a computer tool kit I've had since 1997. I used a large Tiger Balm can, and went ahead and drilled holes in the top.
Here's the picture
13 years ago on Step 6
do you have to use an altoids tin
Reply 13 years ago on Introduction
no
Reply 11 years ago on Step 6
I can see probably using a tic-tac box
11 years ago on Step 3
How loud would this be if I connected it directly to ipod directly (without amp)..
12 years ago on Introduction
i need to use a Old internal computer speaker or i con use something else
Another idea would be to use one of those U-shaped theraputic or whatever pillows and put in 4 speakers for surround sound and maybe put a sub under the matress?
Actually, just put all the speakers at the top part of the matress so you can get surround sound in bed while watching latenight movies. Crank it up and you can feel the vibrations :D
LOL what if the person sleeping drools a lot? Automatic Shock Alarm? lmao
14 years ago on Introduction
ok, so the head phones i used had one blue wire and one red wire going to each earbud which ones do i connect to which port?
Reply 14 years ago on Introduction
Either should be fine, all speakers (well all to my knowledge) are not polarised (Meaning you can put the wires either way)
they are not,yes but you need to connect + to + and - to - to get better sound so it will pump water ,OUT
oops,sound not water
Lmao
what does lmao mean
Reply 12 years ago on Introduction
laughing my a** off
Nope. As he said, speakers are non-polarized. The only time polarity matters is when you have a polarized _setup_ (such as "poor man's surround sound" -- Google it) which can arise in certain stereo hacks -- since you can end up with sound waves canceling each other out, or if you're using a piezo device rather than a speaker (though creating a piezo driver isn't for the non-electronic hoi polloi). Not a problem with a single speaker, though.
Then why does the speaker have + and - written?
For stereo use. You don't want to have one channel producing a wave 180° phase-shifted from the other channel, as that would result in destructive interference.
oh ok
