Introduction: Grease Monkey's Compact Glove Set
I bet you've been there before. You're already late to class or work, and the chain on your bike slips off the sprocket and gets tangled. You know exactly how to fix it quickly, and you do so, but now your hands are full of grease and heavy duty degreaser is nowhere to be found. Or you have to jump start your car. Or bandage a bad cut on a coworker. You may even be reminiscing that roadside tire change last week where this would have been a lifesaver. Having a compact, portable set of gloves close by is way more convenient than having to clean up afterwards.
This Instructable isn't so much a how-to, as much as it is simply a "Hey! You might want to copy this" type of thing. While storing gloves this way isn't exactly new, it isn't the type of thing you see that often either. Also, this guide might be updates over time. To see the latest changes, click here.
Without further ado, let's get into it!
Difficulty: You can do it while watching Youtube vids
Tool Requirements: What's in your kitchen drawer
Time: 'a little while'
Cost: Chump-change$
Disclaimers:
A bit of motivation to keep making Instructables always helps. I'm a participant in the Amazon Services LLC Associates Program as well as eBay Partner Network, affiliate advertising programs designed to provide a means for creators to earn fees by linking to their sites, at no extra cost whatsoever to you.
Step 1: What You'll Need
Plenty of people will have this stuff already. All we need is as follows:
- Nitrile Gloves: Personally, I'm a fan of nitrile gloves since they're excellent all-around gloves. It's chemical and puncture resistant, as well as non-allergenic (latex-free) and non-irritating. 3 or 4 mill thickness is perfect to keep them compact without being overly flimsy. Make sure to choose the right size.
- A sheet of paper: Regular paper, or if you prefer it, wax paper, will be needed. Pretty much anything will do.
- Paper Guillotine and/or Scissors: I'm a huge fan of paper guillotiones, and this is another situation where it's just nicer for straight, equally spaced cuts. Of course, you can use some scissors and a ruler instead.
Note: Even if you intend to use these for a first aid kit, it isn't worth getting sterile gloves since they will come in packaging of their own which shouldn't be opened until they are to be used. Apart from being much more expensive. In a real-world, first aid kit type scenario, having clean gloves is more important than having sterile gloves. The real world isn't sterile, nor will it leave sterile wounds in the first place.
Step 2: Cut the Paper
We're going to need some rectangular strips of paper. When cutting, I just went with the closest suitable mark on the paper guillotine, which was about 1" wide. No need to be precise, but it will look better if the cuts are parallel so the paper's edges match up when looped.
After you have the long strips, cut them roughly in half.
Step 3: Fold and Roll the Gloves
Next we have to roll them. This is the most important step to make the gloves as compact as possible since we have to make sure we get all the air out of them.
Lay them one on top of the other, and fold the sides inwards until you have a long strip like in the second image. All you have to do then is carefully roll them up starting on the finger side making sure you get all the air out through the cuff.
Step 4: Stretch Over the Cuff
Sadly, it isn't enough to keep the gloves from unraveling to just stretch the cuff over the balled gloves. However, if you twist the cuff and stretch it over, it will help keep the gloves cleaner and help it maintain it's shape.
Step 5: Wrap It With the Paper Strip and Voilá!
Wrap the rolled up gloves with the paper strip from before, and secure it with some tape. Said and done.
Finally, we have the finished product! Some compact, clean gloves, perfect for thrashing wrenches or doing some unexpected wound care.
Step 6: Make Some More!
I always make a handful of these at the same time to make the effort more worthwhile. After all, the whole point of this idea is being able to stash them here and there to make sure you have them available when you need them, even if you didn't plan to need them. Throw some in your glovebox, your backpacks, or anywhere or anything else where it might be of use to you if something unexpected happens.
Thanks for reading! If you found this interesting, click the 'Follow' button up on the right to get notified of similar projects in the future, or check out my profile to see what other projects I've been up to — here are some you might like:
![Workshop Hacks Challenge 2017](https://content.instructables.com/FU7/ZMOJ/JA2TN74Z/FU7ZMOJJA2TN74Z.jpg?auto=webp&frame=1&width=320)
