Grocery Bag Jewelry
11,764
74
13
Introduction: Grocery Bag Jewelry
Thrift?  Frugality?  Eco-accessories?  Something you can do while being lazy on the couch?  You got it!
This Instructable shows how to make a macrame bracelet entirely out of grocery bags (and a few beads if you prefer).  This same technique can also be applied to making a ring.
Step 1: Materials
You will need:
  • Scissors
  • Plastic Grocery Bags
  • Lighter
  • Bottle
  • Beads (optional)
Step 2: Cut Bag
Cut off the bottom of the bag.
Using your index finger as measurement, start cutting a long, spiraled band from the bag.  It won't really curl, but think of it like peeling an apple in one solid strip.
Step 3: Make a Wrap
Wrap the grocery bag ribbon several times around a bottle.  Double check that the resulting circle will fit over your hand.
Step 4: Start Knotting
Leave a "tail" of one end of the wrap exposed, and with the other end, start tying a series of half hitches.
Step 5: Knot End and Snip
Knot the "tail" and the end you've been working with.
Snip the excess.
You can stop here if you like!  Or continue on...
Step 6: Make the Twine
This Instructable does an excellent job of explaining how to make rope/twine out of fibers.  The same principle applies here.
Cut a grocery bag into thin strips.
In groups of 4, start twisting it into twine.
Once you have enough (~12"/30cm), you can snip the beginning end and melt it a bit with a lighter.  This will make beading easier.
If you need extra length:
  • Bundle 4 more strips and overlap with a bit of excess where you've already twisted.
  • Twist the new bundle a few times before adding another bundle to the other half in the same way.  This will keep things orderly with minimal confusion and enough fingers to keep going.
  • Once you've worked through a few twists, you can snip away the excess and continue twisting.
The twine is actually quite attractive!
Step 7: Beading
Thread the twine through the half hitch loops and add a bead between the weaving.
Knot the ends and snip excess.
Done!
Unusual Uses: Kitchen Challenge
Finalist in the
Be the First to Share
    • Big and Small Contest
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    13 Comments
    Ninzerbean
    Ninzerbean
    11 years ago on Introduction
    Wow! And a pair of these, just t bit larger, would make great handles on a purse made from bags.
    sunshiine
    sunshiine
    Reply 11 years ago on Introduction
    I made handles by braiding them and it is fine. I have made another one that I haven't published yet but will in a day or two. They make great handles. Have you priced handles at the craft stores? Plastic bags are great for stuff. So glad she posted this.
    AngryRedhead
    AngryRedhead
    Indeed! But the material is a bit stretchy... Still the cost of experimenting ain't much.
    sunshiine
    sunshiine
    I have been experimenting using plastic bags. This is a great idea. My mom probably would try necklaces with them.
    AngryRedhead
    AngryRedhead
    One of my mother's friends used to crochet plastic bread bags into rugs, and I think that's what got me started in experimenting.
    If you do this, please take a picture to share!  I'd love to see what you come up!
    sunshiine
    sunshiine
    Oh yes, I have thought about that. I did use plastic bread bags on a tote for handles. It worked great and actually looked good too. I have it on my page here. The handles were fairly strong because I braided quite a few together.
    sunshiine
    sunshiine
    I have it here If I am not supposed to do this let me know and I will send a pm and delete this message. https://www.instructables.com/id/MRS-RATTATOUILLES-DE-JEUNER-UN-SAC/
    AngryRedhead
    AngryRedhead
    Thanks!  I think using the same material for the bracelet and twine helps keep it cohesive.
    ChrysN
    ChrysN
    Pretty! I'm going to see if I have and plastic bags around. Is that also a ring you make on your finger?
    AngryRedhead
    AngryRedhead
    Thanks!  And yes!  It flairs out to the sides a bit, but fortunately it's squishy and bends.  I used my thumb as a guide for making it, and it ended up fitting my ring finger nicely.
