Introduction: Habitat for Mars
I designed a possible habitat for survival in other planets like in Mars.
Design is Created on TINKERCAD and Fusion.
The habitat is build with saprate 6x Hexagonal Containers,6x hexagonal connecting tunnels and a Hemisphere.
All of them can move individually.
Material Used to make them are depends upon where they will be.
Foe ex. If they are in earth deserts or in mars (like in SAHARA) they shouldd be made with low heat absorbing/material that can reflect heat...(absorbing heat can cause heat up the entier concept).
They are individually transportable.Space grade material will make them light weight.
The habitat is build with saprate 6x Hexagonal Containers,6x hexagonal connecting tunnels and a semesphere.
View 3d file for better understanding.
Step 1: Transport of Containers
Individual parts are easy to transport via trucks,ships,helicopters,cargo planes,rockets.
My design is made with saparate blocks and they need to be assembled after transport.
Step 2: Assembling
After Transporting they need to be assemble in desired experimented order. They can be form/assembl in different shapes nd forms.The design can be improved.
Step 3: Rooms
Each Hexagonal containers can be a saperate or multiple rooms depending upon size.
For space use they must be airtight.
Step 4: Transportation B/W Every Containers/Rooms
There a Hexagonal tunnels which connects every room/container.
Step 5: Power Source
As we know that solar panels/cells are a good example for power source to charge batteries/run actuators/sensors/electrical equipments.So every room/containers and tunnels has movable solar panels...change in sun position will cause change in solar panel position which help to get more power from sun rise to sun set.
They must be made with good quality material that they can handle heat,rain(if happens),storm and other atmospheric powers.
Step 6: Plants/trees
The semicircular hall is a good place for planting trees.
and Also small trees/plants can be planted in every hexagonal rooms/tunnels/containers.
Step 7: Water,O2 Source
Water is the most essential for living of orgnisms, For that They can be carried or can be produced if there oxygen and hydrogen available, by using proper mthod.
This is an entry in the
Make it Resilient
