How to Make a Spray Bottle That Works in Any Orientation
Intro: How to Make a Spray Bottle That Works in Any Orientation
Everyone knows it. Your spray bottle is almost empty or you have to be in a corner where the bottle can't reach in the right position and the spray bottle no longer sprays properly! The hack I show in this Instructable will get you rid of this annoyance forever! By replacing the hard suction tube with flexible tubing and adding a weight to the end of it, the suction tube will naturally fall to the lowest point of the bottle. This will allow end of the tube to stay submerged regardless of how the bottle is positioned.
As always, I've made a short video tutorial again where you can watch this project and see the result in action.
Most of the credit for this idea goes to my grandmother. Unfortunately she is not active online and therefore cannot be tagged! She has been using a similar idea for years and I wanted to make this Instructable from it. As weight, however, she used a stone with a hole in it. Although this idea (but with a small stone as weight) has been used by my grandmother for years, I must certainly give credit to "DIY Hacks and How Tos". Because of his Instructable I replaced the stone for nuts, with a small improvement!
STEP 1: Preparing the Spray Head
To start, unscrew the spray head from the bottle. Cut the original suction tube a few inches below the spray head. Be careful not to get any splashes of the cleanser in your eyes or on your skin. If necessary, rinse everything well with water and wear glasses just to be sure.
STEP 2: Mounting the Flexible Tube
As the title of this step says, we are now going to mount the flexible tube. Slide the flexible tube over the original tube. The flexible tube should be slightly longer than the original total length of the tube.
Luckily I found a tube with 1/8" inner diameter in my shed that fits exactly over the original and closes well. If the tube you use is a bit too small, you can heat it up. If it is too big, you can secure it with some superglue.
STEP 3: The Titanium Nuts
Now slide the 5 titanium nuts over the flexible tube and attach them to the end of the flexible tube with some super glue.
1/4 inch nuts should be best to use because they conveniently fit on the flexible tubing without any adhesive. Unfortunately I didn't have these in titanium so I used a slightly larger size.
Most of you won't have titanium nuts lying around at home. Stainless steel is of course also great to use! The only downside is that most stainless steel nuts will corrode over time. Titanium, on the other hand, is much more resistant to chemicals.
STEP 4: Ready
And finished! Just screw the spray head back onto the bottle and you can use the upgraded spray bottle!
As you can see in the photos and in the video, the bottle can now be used in any position. The nuts act as weight. This will allow end of the tube to stay submerged regardless of how the bottle is positioned.
16 Comments
msheidi 2 years ago
bmail 2 years ago
SylvanB 2 years ago
Glass beads might work better than any metal, being closely related to a "stone with a hole."
bmail 2 years ago
Don't get me wrong...it's a great idea, but the execution of it long term is what seems to be the issue.
Uncadoo 2 years ago
andyfreezer1 2 years ago
michaelb2 2 years ago
leshemeli 2 years ago
JohnW51 2 years ago
jpulkowski 2 years ago
jmacuk 2 years ago
MikB 2 years ago
NEW PEW 2 years ago
I hope they have some kind of technique in all planes...
MikB 2 years ago
DavidF14 2 years ago
jmdushi 2 years ago
