Introduction: Halo Book Ends
This instructable should show you how to make diorama book ends. Your's don't have to be Halo.
Step 1: Clean Off Your Book Ends
If you were like me, and just used old bookends that were laying around you'll have yo clean them first. To do this simply take a damp cloth or paper towel and wipe it down until the dust is gone.
Step 2: Add the Ground
To add your ground, just us clay or similar things (I used model magic). If necessary paint it after you make your ground the way you want it.
Step 3: Grass and Plants
This step is optional I only used grass and no trees. Just use some grass material I used grass paper, but you could just spray paint sandpaper green. To apply it just cut out the pieces you want (it will look better if you just use one big piece), then hot glue them onto the clay.
Step 4: Add Buildings
Also an optional step, but if you don't add buildings I would recommend adding a sky. To make your buildings use cardboard,foam (I used this), foamboard, or anything else you could use to build your structures. then glue them on.
Step 5: Add Props, People, or Animals
This step, again optional is pretty self-explanatory just glue your props, people, or animals on and you're done.
Glue Challenge 2016
