Introduction: Ham & Cheese Egg Muffins
Easy Ham and Cheese Egg Muffins
Step 1:
Put in gloves if you have food allergies.
Step 2:
Set rack in oven to fourth shelf from the top of the oven
Step 3:
Preheat oven to 325⁰ for 20 minutes
Step 4: Required Items
Gather items below:
Medium size bowl
Cutting surface (board)
Sharp knife
Fork
Timer
Measuring cup with a spout for pouring
Measuring spoons
Muffin cups
Muffin Tin with 6-12 molds
Toothpicks
Oven mitts or towels
Cooking spray
12 eggs*
¾ Cup diced ham
¾ Cup diced cheddar cheese
Salt and pepper
Step 5:
Place one muffin cup into each empty mold in the muffin tin
Step 6:
Spray each muffin cup with cooking spray
Step 7:
Dice ham into 1/8th inch squares - set aside
Step 8:
Dice cheese into 1/8 inch squares – set aside
Step 9:
Crack all of the eggs into bowl; remove all shell pieces that accidentally fall into bowl and discard
Step 10:
Add a pinch of salt and pepper
Step 11:
Stab the yolks of the eggs with a fork to break them
Step 12:
Stir the eggs with the fork in the bowl, vigorously, until well mixed
Step 13:
Pour the egg mix into each muffin cup; about ¾ full, leaving room at the top for ham and cheese
Step 14:
Add 1 tablespoon of the diced ham to egg mixture in each muffin cup
Step 15:
Add 1 tablespoon of the diced cheese to egg mixture in each muffin cup
Step 16:
Once oven is finished preheating place the muffin tin in the center of the oven rack and close the oven door
Step 17:
Set timer for 20 minutes
Step 18:
After 20 minutes use oven mitts or towels to pull muffins out of the oven
Step 19:
Insert a toothpick into the center of one of the muffins
Step 20:
Pull the toothpick from the muffin; if it is without any sticky egg residue the muffins are finished cooking
Step 21:
If residue exists on the toothpick place muffins back in the oven for another 3 minutes
Step 22:
After 3 minutes take the muffins out of the oven
Step 23:
Reinsert a new toothpick, pull it out, check for egg residue
Step 24:
If there is residue again repeat steps 23-25
Step 25:
Remove egg muffins from muffin tin to prevent further cooking
Step 26:
May be served hot or cold. Makes 12 egg muffins.
Step 27:
Recipe can be halved or quartered. One egg is equivalent to one muffin.
5 years ago
Those look yummy :) I make something similar sometimes, but I put puff pastry sheets in the bottom of the muffin tin and fill them with the egg mixture.
