Introduction: Handheld Winch
In this Instructable, you will learn how to create your own winch from easily accessible materials for practical, household uses.
Step 1: Supplies
Materials
Compact electric motor of some sorts (a windshield wiper motor in my case)
1"x12" shaft
24" punched flat bar
2x 3" bolts with corresponding nuts
Momentary switch
Electrical Tape
Wires
Power supply (batteries or corded power brick, preferably above 1.5 amps)
Wire Terminals
Wire crimps
Tools
Die Grinder (any metal cutting tool)
Drill
Soldering Iron
Industrial Epoxy
Wire cutters and stripers
Sand Paper
Step 2: Handle
Measure where to cut the handle. Make sure to compensate for the motor. Use the die grinder or preferred cutting tool to cut the handle. After, wrap the handle in electrical tape or sticking foam for added affect.
Step 3: Mount Handle and Motor
Start out by sanding the areas of the handle and motor that will be mounted together for better grip. Apply a generous amount of epoxy onto the handle. Stick the motor onto the handle so the drive shaft is perpendicular. Then, wrap with electrical tape.
Step 4: Cut the Flat Bar
Measure and cut the piece of flat bar into two equal pieces.
Step 5: Mount Flat Bar Onto Drive Shaft
Take the nut off the drive shaft and remove the previously installed arm. Measure the width of the drive shaft and mill the central holes of the two bars, if necessary. Double the bars on top of each other, then tighten the nuts and bolts through the top and bottom holes. After, put the bars back onto the drive shaft and tighten the nut back onto the drive shaft.
Step 6: Beginning of Wiring
Cut and strip the wires coming from chosen power supply. Drill out a hole for the momentary switch and one to make a pathway for your wires.
Step 7: Switch Soldering
Solder one wire coming from the power supply to one terminal on the momentary switch. Solder a second piece of wire to the switch's other terminal that will go towards the motor.
Step 8: Crimp Wires
Crimp a wire to the previously cut wire running from the power supply. This second section of wire will lead up to the motor's terminal. Solder the connection of the crimp for reinforcement.
Step 9: Solder and Plug Terminals
Start by running the last two wires towards the motor. Measure, cut and strip the wires for clean wire management. Solder terminals onto the end of the wires and plug them into the motor's terminals.
Step 10: Power Up and Complete
Connect your winch to your power source and your winch is ready to go.
Step 11: Video
Move It
8 Comments
6 years ago
We are winch rope manufacture from China,This is our Alibaba website:
www.hyropes.com.cn,Buy rope can please contact at:
Violet <Violet@hyropes.com>
7 years ago
About how much can this lift?
Reply 7 years ago
Honestly, I haven't done any testing. But the motor used has an impressive amount of torque so the breaking point would most likely go in the spool.
7 years ago on Introduction
BATMAN!
Oh and BTW, anyone out there thinking what I am; a winch-winch?
Great inspiring project and gets my mental juices (or drops) achurnin. Thanks!
Great way to wind up Christmas lights. or Easter lights.
Cool idea! Thanks for sharing and welcome to the community!
