Introduction: Hanging Shelf With Hidden Storage, Hooks, and Motion Activated Lights
I made a hanging shelf with hooks to act as a place to hang things near my front door. I added the lights with a motion sensor so that when I approached the lights would turn on and I could see around the shelf. You can also remove the front for hidden storage for things that you want out of sight.
o Three 1/2x6x3’ boards
o One 1/2x4x3’ board
o Three single hooks
o One box of 1-1/4” nails
o One bottle of wood glue
o One battery powered motion activated LED light strip
Optional
- Spray paint or wood stain
Step 1: Measure and Cut the Wood
Measure and cut the following pieces using the hand saw and measuring tape
(important note: the actual dimensions of the 4” and 6” wide boards are 3 ½” and 5 ½”)
Step 2: Glue the Main Shelf Together
Glue four of the the ½ x 5 ½ x 2 ½ pieces between two of the ½ x 5 ½ x 2’ pieces and clamp together as shown below
o Glue along all contact points of the wood and clamp where the red clamps are shown
o Leave the clamps on and let the glue dry for 12 hours
Step 3: Nail the Main Shelf Where It Was Glued for Extra Strength
Grab 16 nails and nail two evenly along each surface that was glued
Step 4: Glue the Back of the Shelf to the Main Shelf
Glue the remaining ½ x 5 ½ x 2’ piece to the back of the main shelf
Step 5: Nail the Back of the Shelf to the Main Shelf for Extra Strength
Grab 8 nails and nail them evenly spaced along the pieces that were glued
Step 6: Glue the Front of the Shelf Together
Glue the remaining two ½ x 5 ½ x 2 ½ pieces to the ½ x 3 ½ x 2’ piece as shown below
o Glue the two ½ x 5 ½ x 2 ½ pieces ½” from the left and right edges respectively and centered vertically
Step 7: Screw in the Hooks to the Shelf
Using the screwdriver, screw in the three hooks on the lip below the shelf with 6” between the hooks and the edges as seen below
Step 8: Attach the Lights to the Back of the Shelf
· Use the provided sticky pad to adhere the motion sensor underneath the shelf
· Peel off the paper covering the sticky side on the back of the lights and stick them along the outside edges of the back of the shelf as shown below
Step 9: Paint or Stain the Wood (optional)
Grab your chosen paint or stain and head outside to paint the whole shelf
o I personally taped around the lights and the motion sensor before painting
