Introduction: Headboard for Bed
Hello!
Today I will tell you how I made a headboard for the bed ( you can reed how I did bed ). I couldn't decide which headboard I should do. And then I saw the slatted headboard. I liked it so much that I decided to make something similar. Counted the cost, it turned out inexpensive. Estimated cost $ 35.
Step 1:
At hardware store saw вoards, and I really liked their corrugated structure. The material is alder. The bed itself is made of pine, it is very different in color and texture from the alder. But I still decided to stop at the alder.
Step 2:
I buy:
Boards 1800*45*15 mm - 13 PCs. 28$
Furniture Board 1200*200*20 – 1 PCs 7$
Step 3:
First of all I made shelves. From the furniture Board it came 4 shelves. It's size 30*20 cm.
Step 4:
I'm going to start making the headboard.
I saw off 3 boards 565 mm long (9 boards 45 mm + 8 indents for shelves 20mm). Then I take 2 boards and twist them at a 90 degree angle. I put the shelf against the first Board. Then I put another Board. And squeeze all with a clamp. Fix the second Board. Repeat procedure with the next row.
Step 5:
Then fasten the sides. I will connect with pocket hole jig. It's my homemade conductor
Step 6:
Marking, where i need to drill holes
Step 7:
After I assembled the headboard, I carefully sanded the surface.
Step 8:
I found the rest of the RGB led tape. I decided to use it. I stick it on the perimeter, additionally glue with thermal glue.
Step 9:
It remains only to hang on the wall
Step 10:
The number of shelves and the location you can chose as you like.
Step 11:
In the dark the headboard looks even more spectacular!
Now, the bed was finished. It looks great in the interior. In the evenings, the lighting creates a cozy, romantic atmosphere. It is also important that it is 100% exclusive and the budget is not badly affected.
That's all. Until next time!
Runner Up in the
Multi-Discipline Contest
8 Comments
3 years ago
Very nice headboard! And your homemade pocket hole jig is pretty ingenious. You could make an instructable on how to make one of those - that would be really neat to see the process! : )
Reply 3 years ago
Thank you! Ok i will try to do instructuble for my jig hole. In what category i can post it? In tools?
Reply 3 years ago
I think that would be a great place for it : )
Reply 3 years ago
Hello! As i promised to you:) My Kreg jig pocket hole version 2.0 :))
https://www.instructables.com/id/Pocket-Hole-Jig-Handmade/
Reply 3 years ago
That looks so good, thank you for letting me know. Excellent!!
Reply 3 years ago
Subscribed. Eagerly waiting for the instructable:)
Question 3 years ago
I love this and will definitely make it. How are you attaching it to the wall? I guess that most of the weight is supported by the bed but thinking of the potential for it to dislodge onto my head if not affixed well.
Reply 3 years ago
hello! i used such mounts for shelves on the wall. They are hidden and hold the load well
