Introduction: Hexapod Robot With Ruler Body Parts
This is my first project in instructable . This robot is "HEXAPOD" I made this robot by inspring form different engineering youtube channels and blogs.This Hexapod is successfully made after my four prototype
replacing and eliminating lost of technical problems that came during programing and making suitable body parts .
MATERIALS USED IN HEXAPOD:
1. 30 CM RULER * 4
2. Arduino uno * 1
3. Bluetooth module HC-05 * 1
4. Jumperwire
(male to male 10 pice)
(male to female 5 pice)
(female to female 5 pice)
5. zero board (5*5)cm
6. servo motor sg9
7. powerbank as a power source
Step 1: Ruler Body and Leg Parts
Tools for construction
1. Hacksawblade
2.Hotglue and Hotglue gun
3.scissors
4.SOLDERING iron ,lead ,paste
5.papertape
FIRST IN THIS PROJECT I HAVE TRIED HEAVY WEIGHT RULER BUT DUE TO HIGH WEIGHT I CHANGE IT WITH 30 CM RULER
THE BODY PART CONSIST OF 6 LEGS WITH 6 LIMBS
IN UPPER BODY PART 16 CM RULER IS PLACED IN PARALLEL AND ATTACH HORIZONTALLY WITH 2 ,9CM RULER
FOR THE LEG I CUT THE RULER OF 10 CM LONG WHICH HAS SAPE UPPER PART BIG AND COMMING DOWN THIN.
AS WE HAVE 18 SERVO MOTOR ,WE NEED 18 OUTPUT PIN IN ARDUINO DUE TO NOT AVAIABLE OF 18 DIGITAL PIN I CAME TO A SOLUTION OF MAKING COMMON SERVOS OF LEGS. AS
Step 2: WIRING AND CONNECTION
IN HEXAPOD SERVO 2&3 ARE COMMON IN WIRING, SIMILSRLY
5&6,
8&9,
11&12,
14&15,
17&18
AS I HAVE PUT SERVOS IN CONNECTON COMMON THEY GET SIGNAL AT SIMILAR TIMES
FOR THE MOVEMENT OF THE HEXAPOD THE LEGS MOVES IN THE TRINGULAR FORM
FIRST LEG1,LEG5, AND LEG3
GO UP IN AIR THEN TTHE SERVO 1 AND 7 MOVES IN 105 DEGREE AND WHILE SERVO 13 MOVES TO 75 DEGREE THEN THESE LEG GOES IN INITIAL POSITION TO DEFULT 90 DEGREE.
SIMILARLY OTHER 3 LEGS GET UPWARD
LEG 6,2,4 THEN SERVO 16 &10 MOVES TO 75 DEGREE WHILE SERVO 4 MOVES TO 105 DEGREE FOR THE FORWARD MOVEMENT .
THIS HEXAPOD IS CONTROLLED THROUGH ANDROID APPS AND ANDROID MOBILES .THROUGH THE MIT LAB I HAVE DEVELOP MY OWN APPS TO CONTROL AS I WANT AND REQUIRE FOR HARDWARE. .
Step 3: ARDUINO PROGRAM AND MOBILE APK
THE ARDUINO PROGRAM AND THE ANDROID APPS OF THIS ROBOT ARE SIMPLE TO UNDERSTAND AND USE .
Plastics Contest
5 Comments
Question 2 years ago on Introduction
Could you send me the image of the connection
Reply 1 year ago
here is the connection diagram ,if you want to run from the power-bank then connect the supply in parallel .one from the 5v output of the arduino and another get the 5v from the below point of the arduino usb point directly
3 years ago
Amazing...!
3 years ago
ya ,i have cover of carton box .thanks for your feedback.
3 years ago
This is awesome. If you put a cover on it, it would make an epic Halloween prop.
