Introduction: Holding Concertina Window Shutters With Magnets
Window shutters are a stunning and popular design feature preferred by many homeowners seeking to replicate the authenticity of Victorian housing. Although solid wood window shutters were a standard feature in many Victorian houses, designed to help keep the cold out and warm air in there are often installed in modern homes to block out light and noise and make a room feel warm and cosy.
Like many old properties, windows are not always perfectly straight which means that newly installed window shutters sometimes do not stay together when open. With a few strong magnets, steel plates, a bit of wood filler and patience it is easy to create hidden magnetic fastenings.
Step 1: Create a Groove
First, chisel out a groove in the left-hand panel of the concertina shutters. An ideal sized magnet for this project a 50mm x 10mm x 1.5mm neodymium magnet. You can get these direct from first4magnets.
Step 2: Insert the Magnets
Push the magnets in to the groove and secure in place using adhesive.
Step 3: Fill Over With Wood Filler.
Fill in the groove with wood filler
Step 4: Fix Correspending Steel Plate
Fix a steel plate to the right-hand panel of the concertina shutters so that it lines up perfectly with the concealed magnet
Step 5: Finished
Enjoy your new shutters!
8 years ago on Introduction
This is super helpful, thanks for sharing!
